Big problems
Old Oct 18, 2010 | 11:12 PM
caa5030's Avatar
caa5030
Default Big problems
You may have read my post about the first time at the track in general disscussion. It may have been placed under the wrong category. I was wondering if you guys, who most have more experience with the c5 than myself, could suggest some things to check before I go further than I may need to.
On my second run at the track, when I went to gun it out of the hole it probably did not even move an inch. It felt like the car wanted to move but it was just slipping too badly. It is a 99' FRC 6-speed. All stock except a catback exhaust and 60,000 miles. It doesn't grind or make aweful noises. It just doesnt move. None of the forward gears work and neither does reverse. I don't know where to begin looking. Clutch, slave cylinder...something more serious. If you guys could throw me a few pointers I appreciate it. Thanks.
Old Oct 18, 2010 | 11:24 PM
lucky131969's Avatar
lucky131969
Sounds like an output shaft........
Old Oct 19, 2010 | 04:59 AM
dougbfresh's Avatar
dougbfresh
Probably shouldn't be going to the track if you don't know how to wrench on your own car.
Old Oct 19, 2010 | 06:18 AM
PEERPSI's Avatar
PEERPSI
Tough crowd.
Old Oct 19, 2010 | 06:40 AM
Corvette Don's Avatar
Corvette Don
Output shaft is what it sounds like - http://forums.corvetteforum.com/c5-p...h-springs.html
Old Oct 19, 2010 | 07:22 AM
caa5030's Avatar
caa5030
Dougbfresh that is how you learn. I am not afraid to dig into it.
Old Oct 19, 2010 | 09:31 AM
dougbfresh's Avatar
dougbfresh
Well getting the trans out to fix this ought to get your "shovel" a workout. It's not if but when you'll break something at the track-have your wallet stocked.
Old Oct 19, 2010 | 09:55 AM
caa5030's Avatar
caa5030
Pay to play the game!
Old Oct 19, 2010 | 09:21 PM
rried2tall's Avatar
rried2tall
Default no gears
Doesn't look like your getting much in the way of helpfull ideas does it, does your clutch feel normal, same foot presure, did you car make any kind of noise when the gears stopped working. it is a major job getting to the clutch, torque tube and trans and rear. If your going to do the work get manuals, if not find a good shop and good luck.
Ron
Old Oct 20, 2010 | 06:57 AM
caa5030's Avatar
caa5030
I didn't get a clutch smell and the petal feels the same as always. I am leaning toward the rear end. I am going to pick up the car tomorrow. It is at my buddy's house still. (Shorter tow)
Old Oct 20, 2010 | 07:02 AM
lucky131969
While other possibilities do exist...this is classic output shaft failure, and has already been brought up.
Old Oct 20, 2010 | 10:43 AM
dankhts's Avatar
dankhts
What happens when you try to put it in gear? How about if you try to put it in gear without dis-engaging the clutch? Does the shift linkage still feel like it's connected to something? Any noises?
Old Oct 20, 2010 | 05:12 PM
road pilot's Avatar
road pilot
2016 C5 of Year Finalist
I agree!!!
Old Oct 20, 2010 | 09:21 PM
caa5030's Avatar
caa5030
Thanks guys. I appreciate it. Going to pick it up tomorrow, then time to start in on it.
Old Oct 23, 2010 | 02:17 AM
Mike Yeager@Eastcoast Performance's Avatar
0Mike Yeager@Eastcoast Performance
Former Vendor
Its one of 3 output shafts, more than likely its the driverside...LMK if I can help you with anything...
Old Oct 23, 2010 | 03:07 PM
Dave68's Avatar
Dave68
Here's a question: Is output shaft failure (typically) the result of repeated hard use? That would be my guess and that there is a heavy-duty version available.
Old Oct 24, 2010 | 12:17 PM
todd@rpmtransmissions's Avatar
0todd@rpmtransmissions
Former Vendor
When you get the car, put it in gear and let out on the clutch. Watch the speedometer. If it moves, then the transmission and output shaft are fine, and you probably broke an output shaft in the differential. If it doesn't move, then you broke the output shaft in the transmission.
To Big problems
Old Oct 24, 2010 | 01:53 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Heres a couple of excellent post that you can use to see what is in the rear and how you can repair it:
- C5, Its Go Time, Output Shaft Install - Left and Right : http://forums.corvetteforum.com/c5-t...post1573404441
- C5 RAGTOPWS6, Differential UP-Grade; http://forums.corvetteforum.com/c5-g...-z06-guts.html
Old Oct 24, 2010 | 02:27 PM
caa5030's Avatar
caa5030
I actually twisted off the passenger side axel out at the wheel. I am amazed at this.
Old Oct 28, 2010 | 06:16 PM
caa5030's Avatar
caa5030
I was wondering, Who are some of my go to vendors on here? I am thinking of replacing both even though only one is broken. Should I consider buying beefier ones if I plan on staying close to stock?
