No Horn
Old Oct 31, 2010 | 04:36 PM
pikerunner's Avatar
pikerunner
Default No Horn
I just noticed that my horn does not work. I swiped out both the fuse and micro relay under the hood and apparently are OK. Also, the panic horn/security works fine.
Any thoughts? Thanks.
Old Oct 31, 2010 | 05:33 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
Since the panic portion of things works, then the horn and wiring are all good at that point. I would think the horn switch itself in the steering wheel is having issues. I saw a write-up in here a while back concerning this. Use the search function.
Old Oct 31, 2010 | 06:56 PM
robsc501's Avatar
robsc501
Hi There,
This maybe what you are looking for.Forum search type horn membrane fix
robsc501
To No Horn
