Cam Recomendation
Old Nov 1, 2010 | 05:30 AM
MR.Z06's Avatar
MR.Z06
Default Cam Recomendation
408 stroker
11.1 comp
3.42 gears
M-6 trans
Street car
91 oct pump gas
Occasional N20 use (200 shot)
Nothing stickier than a 305/35-18 Drag radial
ETP 245cc Cathedral port heads (64cc chambers)
Dual valve springs rated to .650 lift TI retainers
1-7/8 or 1-3/4 LT headers?
X pipe NO cats
Stock TI mufflers with Bridge mod
Weiseco flat top pistons
60lbs injectors
Walboro 255lph pump/Racetronics hotwire kit
What kind of cam should I be running? Specs?
Opinions welcome.
Thanks.
Old Nov 1, 2010 | 07:02 AM
AU N EGL's Avatar
AU N EGL
and pass CA smog ?
Old Nov 1, 2010 | 11:13 AM
MR.Z06's Avatar
MR.Z06
I said no cats so no I'm not worried about smog.
Old Nov 1, 2010 | 11:29 AM
AU N EGL's Avatar
AU N EGL
With all those parts you mention, Are you going to do the build yourself?
being an occasional N2 use, that would mean a smallist cam.
Do you have those heads now?
and dont worry about the springs until you select your cam.
Old Nov 1, 2010 | 11:50 AM
MR.Z06's Avatar
MR.Z06
I already have the engine. It's currently in my Camaro. I'm swapping it to my Corvette. While it's out I'm thinking of changing the cam. Looking for general recommendations.
Old Nov 1, 2010 | 12:50 PM
thechosenone's Avatar
thechosenone
For nitrous, cams that have less exhaust overlap and more exhaust duration are best. However, it is best to choose a cam tailored to normal use (when nitrous is not activated) since 99% of most vehicle operations is not at full throttle. There are special cam grinds available for nitrous competition which have more aggressive exhaust profile ramping, etc. Since cam selection depends largely on vehicle weight, gearing, etc., it is best to stick to cam manufacturers' recommendations for your particular goal.
I would also get 3.90 or 4.10 gears put in and go with 1 7/8 LTH!
Old Nov 1, 2010 | 11:09 PM
rustyguns's Avatar
rustyguns
whatever you get.... get the biggest one! you won't regret it!
Old Nov 2, 2010 | 07:10 PM
J.R.'s Avatar
J.R.
Option:
Go over to LS1tech forum and contact PatrickG. For $25 get it custom designed for your application. Pretty cost effective way to get the right cam as long as your plan is to purchase a new cam and not try to find one that may work for your application.
Old Nov 2, 2010 | 07:15 PM
ZZ06's Avatar
ZZ06
i really cant comment on the cam for nitrous but with those cubes id recommend the 1 7/8 sized headers.
Old Nov 2, 2010 | 08:07 PM
tlove32's Avatar
tlove32
Your cylinder head flow should dictate your cam choice. Do you have any idea what those heads flow?
Old Nov 2, 2010 | 08:08 PM
tlove32's Avatar
tlove32
Originally Posted by J.R.
Option:
Old Nov 2, 2010 | 08:11 PM
WKMCD's Avatar
WKMCD
Contact Shawn at VA Speed. He has a HUGE amount of experience with those heads.
Old Nov 2, 2010 | 08:25 PM
thechosenone
Option:
He has done all my buddy's cam's and he is the best around! When I wanna get serious on my set up ill switch to a custom cam for now my Trex will do!
Old Nov 2, 2010 | 09:09 PM
dossdrop's Avatar
dossdrop
ive got a texas speed ms3 605/610 237/242 112 i love it. Big enough to make good power and sound killer, but still a very street friendly cam.....just my .02
To Cam Recomendation
