Overheating Problem - SOLVED
Old Nov 3, 2010 | 04:42 PM
123Gone's Avatar
123Gone
Default Overheating Problem - SOLVED
Re: 2002 C5 with about 65,000 miles.
Turn the A/C on and the engine would eventually redline. Took it to the dealer and they changed the coolant and thermostat. That did not solve the problem. Took it back to the dealer. Coolant system pressure was OK, so it was not the cap. Finally figured out the radiator was clogged. Installed a new radiator and that fixed the problem.
Not sure exactly how the radiator became so clogged.
Old Nov 3, 2010 | 04:59 PM
memphis_vette's Avatar
memphis_vette
clogged internally? The fins in the radiator need to be cleaned out every once in awhile as they accumulate a lot of debris. i could not even see through my radiator b4 i cleaned it. car runs about 20* cooler now
Old Nov 3, 2010 | 05:18 PM
123Gone's Avatar
123Gone
Yes, clogged internally. I'm aware with the potential debris in the fins problem. I keep them pretty darn clean.
Old Nov 3, 2010 | 05:31 PM
CHJ In Virginia's Avatar
CHJ In Virginia
Possibly mixed some of the green coolant in with the DexCool ? That can cause some nasty garbage when the two combine - NOT compatible.
Old Nov 4, 2010 | 08:39 AM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
Yeah, I was wondering the same thing.
Old Nov 4, 2010 | 09:47 AM
123Gone's Avatar
123Gone
Did not mix coolant, but did not change the coolant until recently. I was going with the 100,000 mile thing.
Old Nov 5, 2010 | 03:02 PM
Dave68's Avatar
Dave68
As 8vette7 said, it's 5 years or 100,000 miles, whichever occurs first. That explains why your radiator was clogged. Hey, now you know!
Old Nov 5, 2010 | 03:17 PM
PMPNSEZ's Avatar
PMPNSEZ
The C5's pull air from underneath the car which causes them to pick up lots of debris ie leaves cigarette butts etc... Need to blow out the radiators on these cars numerous times a year. I've installed a screen underneath the car to keep debris from entering in the radiator area. Hope this wasn't redundant for anyone and can help someone understand the car better
Old Nov 5, 2010 | 03:21 PM
K RIPPER's Avatar
K RIPPER
NOT CHANGING coolant@ 65,000 miles will NOT clog your radiator I doubt it would get cloogged if you left it in for 100K OR MORE providing the mixture was correct if the mixture had too much water and the car sat for an extended period MAYBE .radiators don't get clogged esp. the newer alum. ones as the coolant passages are significantly larger than the older copper/brass ones .mY guess is that that radiator was compromised during manufacture internal passages blocked of crimped.I have seen that numerous times.Changing coolant while good practice esp. a car like the corvette,but it doesn't turn to acid or mud or anything that would clog it up
Old Nov 5, 2010 | 03:28 PM
DeadFred's Avatar
DeadFred
St. Jude Donor '08
How are you supposed to clean them?
Old Nov 5, 2010 | 07:17 PM
Paul 75 L82's Avatar
Paul 75 L82
The only way I've ever cleaned a rad is to remove it from the car and take your garden hose with a nozzle and flush it from both ends till everything runs clear.
Old Nov 5, 2010 | 07:48 PM
lucky131969's Avatar
lucky131969
The owners manual is soo confusing.....sheesh....
Old Nov 6, 2010 | 12:40 PM
VETSTYL's Avatar
VETSTYL
Default Cleaning Radiator
So is this the way to clean the radiator? On visual inspection I do not have any dirt, leaves, bags,, etc. However I do start overheating in stop and go traffic/long idles. Checked the standard sfuff.
Old Nov 6, 2010 | 01:18 PM
Dale002's Avatar
Dale002
I've run radiator cleaner on my cars every three years or so and change the coolant.
Haven't had any internal radiator issues in the last 30 years.
To Overheating Problem - SOLVED
