HEADLIGHT shakes will driving
Old Nov 22, 2010 | 12:19 AM
LoneStarFRC's Avatar
LoneStarFRC
Originally Posted by C5Rme
In my case, the HID Bulb felt pretty secure in the housing. I'll have to go double check to make sure everything is tight and see what I can find... Also going to check out the insulator flex boots/limit stops. Hopefully I can find the problem... this is so annoying...
Those little "stop pads" (a much more descriptive term IMO) can be pulled off - sometimes a little too easily I think - and then turned around 180* and pushed back onto the metal tab they live on so that the metal "bar" part of the mechanism that makes contact with them has a "fresh" surface, instead of the trough that gets mushed into them over time.
Old Nov 23, 2010 | 11:13 PM
C5Rme's Avatar
C5Rme
I feel dumb asking, but can someone post a picture of this?
Old Nov 24, 2010 | 03:55 PM
Linn's Avatar
Linn
8th Gear
I would really like pics as well.
My passenger side headlight is shaking on every small bump. :/
Old Nov 28, 2010 | 08:44 PM
C5Rme's Avatar
C5Rme
You and me both Linn... hey, is the left to right adjustment bolt that attaches to the housing on the inside side of the car loose at all? or slightly curved?
Anyone have any ideas? My bulb appears to be VERY secure in the housing... all bolts are tight... I'm stumped... I have no idea what the problem is...
Old Nov 28, 2010 | 08:46 PM
C5Rme's Avatar
C5Rme
My shaking isn't on EVERY small bump, but as soon as I hit 60+ on the freeway i get a pretty consistent jitter... could it be my alignment? My car is lowered, but I had it aligned after I lowered it... about a year ago...
Old Nov 28, 2010 | 09:17 PM
lionelhutz's Avatar
lionelhutz
You can find the plastic bushings if you look in where the arm is attached to the motor. There is also a couple on the back of the headlight assembly. However, I doubt it's the issue. The motor jambs the lifting arm against this stop and if you remove the plastic bumper then the arm is jammed against the metal tab instead. Either way, there should be no play at that contact point.
Peter
Old Dec 3, 2010 | 02:57 AM
C5Rme's Avatar
C5Rme
Peter
I didn't think it was that after figuring out what plastic bushings we were talking about.
Old Dec 4, 2010 | 01:11 AM
Cratecruncher's Avatar
Cratecruncher
My hunch is that something on the drivers side headlight has come loose or come apart on the OP's car. I was just working on my headlights today (broken gear) so have a fresh sense of how they operate.
If my car were doing this I'd remove the painted panel covering the top of each headlight (there are 4 torx screws and the panel just lifts off. Then I would compare the two assemblies trying to figure out why one is loose and the other is tight. Try it raised and lowered. Look at where the linkage stops on each etc. Also check that the motor spins the linkage all the way to the bump stop and tightens the linkage. You might need a new gear but my bet is a bolt has come loose or a nut has fallen off the assembly somewhere. The linkage should definitely not have play from side to side.
Old Dec 4, 2010 | 09:22 AM
JropTop's Avatar
JropTop
There was a thread on this issue a while back and I cant seem to find it,but I had the same issue,and neither the plastic bumber stops or loose mounting bolts were the issue! If you remove the headlight door panel,and the plastic bezel,you will see where the adjusting rods (up/down)
(left/right)fit into the rear of the headlight assembly.That part is plastic and does have some play in it.What I did was use zip ties to eliminate the looseness,but still be able to adjust them if necessary,and THAT fixed MY jittering issue,worth a try
I FOUND IT!!!!!!!!! CLICK ON THE LINK
http://forums.corvetteforum.com/c5-t...gle-found.html
Old Dec 5, 2010 | 05:36 PM
C5Rme's Avatar
C5Rme
I tried this zip tie trick about 2 weeks ago... it hasn't helped. I do believe this is where my problem originates however.
Old Dec 31, 2010 | 04:05 AM
RedRiderZR1's Avatar
RedRiderZR1
Thought I would post in this thread since I found out why my drivers side light was shaking. One of the rear mounting bolts was gone on the top of the mount. Put in a new bolt and made sure all other bolts were snug while I had it apart. Solid now. Was so busy looking for problems on the top and the pieces that swivel I didn't notice the missing bolt from below.
Old Dec 31, 2010 | 07:39 AM
runner140*'s Avatar
runner140*
Originally Posted by Carcass
When the headlight opens,there are stops that limit it's travel(under the hood,directly behind the light assembly).
There should be some rubber or hard plastic "bumpers" over the metal stops.
If one or both of these are missing,it could be causing the "jiggle"
Just get a piece of 5/16 or 3/8 fuel or vacuum line,cut a couple of 1/2" long pieces,and slip them over the stops,this should tighten things up.
Also,a bulb that's not seated into the reflector assy. correctly will jiggle when you hit a bump-
The stops were my guess....last month I rebuilt both headlights and the stops were shot. Replaced with tubing from Home Depot.
Old Jan 11, 2011 | 11:46 PM
  #33
f6john's Avatar
f6john
I have the same issue with my drivers side headlight. Was the missing bolt something a person could see without any disassembly of the headlight housing? My car is in the garage but no heat out there and it's 24 degrees right now. Did you source the missing bolt from the dealer or hardware store, ect. ?
Old Oct 27, 2011 | 08:58 AM
  #34
nathanh0's Avatar
nathanh0
Helloooo
I just replaced both headlight gears on my vert and come to find the previous owner already had metal gears in them. His gears were grinded down bald. wow.
Ok anyways, having the same issue with my headlight on the driver side. It's actually "unscrewing" the main bolt. It unscrewed the main bolt after 4 up & downs.
I'm actually now kind of worried how I'm supposed to make the bolt stay on when the headlight is unscrewing it. Extra tight I guess? The washer isn't doing its job.
I will change the flexiboot thingies (white things? w/e boot is a horrible term for white bumpers).
