wheel spacers
Old Nov 10, 2010 | 11:11 AM
kj217's Avatar
kj217
Default wheel spacers
i want to buy some wheels spacers for my 99 C5 rears,,
who sells them?
what size if i wanted to keep the stock hub studs?
KJ
Old Nov 10, 2010 | 12:09 PM
dgoetz's Avatar
dgoetz
Found a solution that didn't require replacing studs. Used extended thread lug nuts that fit inside of the wheel and ad .3 in of thread which makes up the .25 in of thread lost. They require a 5/8 in. dia hole in the rim that the accs wheels already had. The stock rims were 19/32, which required me to drill out the hole a 1/32 of an in. The wheels don't center off of the stud through the hole but from the 60 deg conical edge of the lug nut so centering was no problem. This proceedure cost me $60.00, which has to be alot cheaper than replacing all the studs.
I have used this set up for 4 yrs with no problems, I think you could go to as much as a 3/8" thick spacer with this I .
Old Nov 10, 2010 | 06:15 PM
Its_Go_Time's Avatar
Its_Go_Time
I use .190" spacers with factory studs and lugs and wheels, and the threads are just starting to protrude from the nut. I would say that about .2" is the max you can go before you need to change something (studs/lugs). It depends a lot on the wheels though. If you need to go thick, Doug Rippie Motorsports makes nice spacers that center on the hub, and have another hub machined onto them to maintain hub centricity. Locating off of the lugs seems kind of cheesy
Old Nov 10, 2010 | 08:06 PM
DaBoz's Avatar
DaBoz
Stay away from Pfadt wheel spacers. What they show on their website is not what you'll receive in the mail.
Ask me how I know....
Old Nov 11, 2010 | 05:04 AM
kj217's Avatar
kj217
where did you get the .19s?
Old Nov 11, 2010 | 05:35 AM
Its_Go_Time
I made them at work. I'm kinda "frugal", you see...
Old Nov 11, 2010 | 06:00 AM
RLYSLO's Avatar
RLYSLO
St. Jude Donor '08
The folks at CCW made some up for me at a decent price. Just give them a call. Great folks to do business with : http://www.ccwheel.com/contact.php
Old Nov 11, 2010 | 09:48 PM
Got uid0's Avatar
Got uid0
St. Jude Donor '17
but prefer adapters with longer bolts over spacers.
Old Nov 12, 2010 | 06:19 AM
tstar's Avatar
tstar
St. Jude Donor '11-'12-'13-'14-'15
I used these guys;
http://www.motorsport-tech.com/hub_rings.html
Custom made to any thickness and they are Hub and Wheel centric. They are not the cheapest but they are excellent spacers.
To wheel spacers
