C5 Code rest
Old Nov 13, 2010 | 12:52 AM
Jasondaugherty's Avatar
Jasondaugherty
4th Gear
Default C5 Code rest
I have a 2001 C5. I know how to enter the manual diagnostic mode and reset the codes. I am getting ABS and Traction Control codes that reappear as soon as I reset them. I just had the brakes done, but the codes won't go off. Does anyone know how to get them to turn off or override the system? Thanks The code is C1214 H C. I just need to get the computer to stop the service notifications and turn off the dash lights. Any way this can be achieved?
Old Nov 13, 2010 | 01:58 AM
manley845's Avatar
manley845
Fix the problem. The codes don't set for no reason.
Let us know how things turn out.
Just curious, what did you have done to the brake system? Just pads and rotors? Or was the system actually opened up that would have required bleeding? Maybe there's air in the system or something.
Old Nov 13, 2010 | 06:24 AM
trussme's Avatar
trussme
Default good info for your issue
check out Post #69 in this sticky:
Sticky: The Improved***** Ultimate DIY Thread ... ******* (Multi-page thread 1 2 3 ... Last Page)
Old Nov 13, 2010 | 08:18 AM
Mark C5's Avatar
Mark C5
St. Jude Donor '08-'09-'10
If you didn't have the problem before the brake job, I'm betting you knocked off a wheel speed sensor.
Old Nov 13, 2010 | 06:03 PM
Jasondaugherty
4th Gear
Default C5 code reset question
The code is C1214 H C. I just need to get the computer to stop the service notifications and turn off the dash lights without getting to the actual repair just yet. Any way this can be achieved?
Old Nov 13, 2010 | 06:14 PM
trussme's Avatar
trussme
Originally Posted by Jasondaugherty
I have a 2001 C5.
No He** No...
C1214 is like the common cold....you ever stop it?....now go read my Post #69 I refered you to in above response & you will know what to do...c'mon, do it.
Old Nov 13, 2010 | 08:01 PM
dougbfresh's Avatar
dougbfresh
That is an EBCM relay code. www.absfixer.com can repair the module.
Old Nov 13, 2010 | 10:28 PM
Jasondaugherty
4th Gear
Default Thanks
Thanks Doug, looks like absfixer is the ticket. Now I just have to get that damned thing off.
Old Nov 14, 2010 | 05:23 AM
trussme's Avatar
trussme
Jason...I put a "EBCM removal procedure" complete with photos, in PDF format, in this:
Post #69 in the C5 Tech sticky titled:
...OR, if you PM me your email address, I will send it to you as an attachment that you can Save & Print for reference while you tackle this 30 minute job.
Bill Trussell
Old Nov 14, 2010 | 07:37 AM
dougbfresh's Avatar
dougbfresh
Removing the EBCM is easier from below, remove the top 2 screws from the top and the other 4 from the bottom-MUCH easier.
ABSFIXER has instructions on his website with pics for removal.
To C5 Code rest
