How to clean Rust from Rotors????
Old Apr 5, 2002 | 12:04 PM
RCswish's Avatar
RCswish
Default How to clean Rust from Rotors????
My car has caught a little rain then BOOM, rust on the rotors. It is fairly new rust if you can even call it that (copper colored Residue?). How can I clean this off w/o doing anything harmful to my rotors. Thanks :)
Old Apr 5, 2002 | 12:16 PM
YLWFVR75's Avatar
YLWFVR75
SE Michigan Coordinator
CI 3, 4, 5, 6, 10 Veteran
St. Jude Donor '09-'11,-'13-'14-'15
Default Re: How to clean Rust from Rotors???? (RCswish)
Drive it around the block, when you press on the brakes it will go away! :yesnod:
Old Apr 5, 2002 | 10:28 PM
C5XTASY's Avatar
C5XTASY
Same thing will happen when you wash the car. As mentioned, drive it a little and stop once or twice. Voila! The rust is gone!
Ed
Old Apr 5, 2002 | 10:49 PM
vstella's Avatar
vstella
A very temporary situation....Drive and apply brakes ...poof ,all gone:D
Old Apr 5, 2002 | 11:02 PM
Dave68's Avatar
Dave68
Default Re: How to clean Rust from Rotors???? (y2k02c5)
Exactamundo!
Old Apr 6, 2002 | 12:46 AM
MTWallet's Avatar
MTWallet
Default Re: How to clean Rust from Rotors???? (Dave68)
You could spray WD-40 or silicone spray on them to keep the rust from coming back! :lol::lol::lol::lol:
[Modified by MTWallet, 10:47 PM 4/5/2002]
Old Apr 6, 2002 | 04:22 AM
WALLstAL's Avatar
WALLstAL
St. Jude Donor '05
You might have a problem stoping.
Old Apr 6, 2002 | 07:25 AM
Driller's Avatar
Driller
St. Jude Donor '10
:rolleyes:
Old Apr 6, 2002 | 08:09 AM
WHY2KRAG's Avatar
WHY2KRAG
Default Re: How to clean Rust from Rotors???? (Driller)
Drive it and apply pressure to brake pedal----all gone But for the die hards Zinc is the answer --plated :cool: :cheers: :seeya
Old Apr 6, 2002 | 09:11 AM
Oldvetter's Avatar
Oldvetter
Default Re: How to clean Rust from Rotors???? (MTWallet)
WD-40 or silicone spray on the rotors doesn't last long. For a real longtime solution, spray on your brake pads also. Better yet use synthetic bearing grease on brake pads, it lasts longest, plus your brakes will NEVER make noises.
Who cares if brakes work, LOOKS ARE EVERYTHING ! :lol: :lol: :lol: :lol:
Old Apr 6, 2002 | 10:52 AM
Jason Squires's Avatar
Jason Squires
Start you car, seat belt buckled, put it in gear, press the accelerator peddle, press the brake peddle, repeat several times - presto change ooh my goodness the rust is gone !! :cheers:
Old Apr 6, 2002 | 11:05 AM
Jim 47's Avatar
Jim 47
Gee :rolleyes: I was thinkng about getting my rotors clearcoated. :eek:
Do you think that might work??????? :confused: :confused: :confused:
Old Apr 6, 2002 | 02:29 PM
YLWFVR75's Avatar
YLWFVR75
Default Re: How to clean Rust from Rotors???? (Jim 47)
If you do that, your gonna have the shiniest set of rotors around :lol: :lol:
Old Apr 6, 2002 | 03:56 PM
shockwave's Avatar
shockwave
Ditto to the above....The rust will most likely be rubbed off in the first 200 feet of driving.
Old Apr 6, 2002 | 09:04 PM
RCswish's Avatar
RCswish
Thanks for the snide remarks and rolling eyes:lol: ! There are so many rolling eyes in here I thought I was in a room with a group of teenage girls....I know, I know, stupid questions get stupid answers (it's pretty funny though:lol:) . I will try to be a bit more articulate with this post. I am not concerned with the portion of the rotors that the brake pads create contact with, I have rust on the center of the rotor. I believe it is called the rotor hat. This rust does not go away when I turn the key, buckle up, adjust the visor and drive the car. The Silver painted portion in the picture below is the part of the rotor I am concerned about. (I stole this pic off another post :blueangel: )
[Modified by RCswish, 1:06 AM 4/7/2002]
Old Apr 6, 2002 | 09:14 PM
borba's Avatar
borba
Maybe use some rustloem paint (black) in the hat area (center). Anything to keep the moisture off the unprotected surface that causes surface oxidation. ;)
Old Apr 6, 2002 | 09:31 PM
AP's Avatar
AP
I would paint it in a similar way .... I know that my dad painted his to match the car ..... Electron Blue ... and also did the calipers in that color ... it looks really good and keeps the rust away ...
To How to clean Rust from Rotors????
Old Apr 6, 2002 | 10:12 PM
SNW Vette's Avatar
SNW Vette
Hi,
I have had good luck using a rust converter (not Navel jelly) from the hardware store. This stuff turns rust into some compound that will not let the base metal rust again! Several brands are available all of which turn a rusted surface black. The trick is to leave some rust on the surface to get the reaction. Try some place like Pep Boys that has a DIY auto paint section. You can also paint over this treated metal as it acts like a primer. I have even brushed this stuff down the rotor cooling vanes a ways to clean up the OD of the disk. It looks much better than rust even without paint.
Like the ad says: “Better Living Through Chemistry”.
Good luck,
Steve
Personal grooming tip: It will stain your hands & finger nails black. You may want to use some of those sissy rubber gloves (Like I do!).
:seeya
Old Apr 6, 2002 | 10:45 PM
John Shiels's Avatar
John Shiels
From: Buy USA products! Check the label! Employ Americans
Default Re: How to clean Rust from Rotors???? (SNW Vette)
Por 15 high temp paint may work or get aluminum hats :seeya
Old Apr 7, 2002 | 12:14 AM
Jim 47's Avatar
Jim 47
Ok Swish, I've got a serious answer for you instead of my previous "smart as-" reply.
This works for regular street driving NOT race track driving. I got some high temperature Al Paint that is used on exhaust systems and painted the Hats. It held up fine on the street, but when I went to the race track a few weeks ago (Summit Point), it destroyed the paint because the brake rotors got very hot. I also noticed that Eckler's has rotor hats for sale in either red or black. I'll try to be more serious next time , but I can't guarantee it. :D
