Shifter replacement question
Old Nov 30, 2010 | 03:43 PM
paulgroleau's Avatar
paulgroleau
Default Shifter replacement question
I plan on replacing my stock C5 shifter with a C6 shifter. I know that the base on both units are the same externally, but are they the same internally? If I replace just the shift & keep my C5 base, will I get the same results as if I replaced the shift & the base from a C6? thanks, paul.
Old Nov 30, 2010 | 03:54 PM
hotwheels57's Avatar
hotwheels57
The "box" is the same. The difference for awhile between the C6 vs C6 Z06 shifters was that the latter had solid bushings that held the "box" above the torque tube (like the C5 vs C5 Z06 shifters). The coupe/convertible came with rubber bushings to reduce noise into the cabin from vibrations.
If I'm not mistaken, the latest version C6 and C6 Z06 shifters come with rubber bushings for all models. I'm not sure about the aluminum shift pattern cap on top of the ergonomic ****. Those were different at one point to differentiate the Z06 from coupe/convertibles. It was only a minor cosmetic detail.
For the price of a complete shifter assembly including the "box", you're getting brand new parts that have no wear and a new plastic bushing at the end of the lever. Some people prefer to buy the complete assembly. And fwiw, some people have broken the plastic bushing during R&R.
Old Nov 30, 2010 | 06:30 PM
road dog's Avatar
road dog
If your going to replace the whole shifter I'd go with the RSD snap shifter its a modified C6 zo6 shifter with a shorter throw a real sweet shifter
Old Nov 30, 2010 | 07:31 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Yep,,,, There the same. Heres the picture of a C5 ZO6 lower box with solid bushings:
Stock shift lever and plastic ****.
BC
To Shifter replacement question
