Help????
Old Nov 30, 2010 | 03:57 PM
beaners's Avatar
beaners
Default Help????
I have been doing collision work for 26 years.. Having a hard time with my rebuild.. Been 2 the dealership many!!!!! times want to glue the front end on and the good bumper cover bolt on has studs.. The other does not. have ordered a few, My ? is do I need to bolt the front end together and glue with the cover bolted to the fenders??? there is no way I can get 2 different types of bolting together with the fenders on. wanted this project done by now but S#%t not going to happen.. Please help!!!
Thanks for any and all replies....
Old Nov 30, 2010 | 03:59 PM
dougbfresh's Avatar
dougbfresh
??? Can't make heads or tails out of your question.
Old Nov 30, 2010 | 04:11 PM
AnteVenom's Avatar
AnteVenom
Cruise-In IV Veteran
Daytona Jam 1 Veteran
I replaced my front bumper/cover this past spring. WOuld be glad to see if I can help you out but I too am not getting what it is you are asking?
Old Nov 30, 2010 | 04:13 PM
beaners's Avatar
beaners
One fender was good and the bracket that went behind the front fender- to cover has studs/bolt on it. the ones they keep giving me slide on to the fender but there is no way I can get my hands in there to bolt together, Also the original has the little bracket for the front inner fender to bolt to for alignment. I will try to get pics soon... Thanks
Old Nov 30, 2010 | 05:02 PM
dougbfresh's Avatar
dougbfresh
I R&R'd my bumper cover before-no drama at all.
Old Nov 30, 2010 | 05:26 PM
beaners's Avatar
beaners
There is crap on there also sorry....
http://i936.photobucket.com/albums/a...t/DSC03134.jpg
Old Nov 30, 2010 | 08:42 PM
PEERPSI's Avatar
PEERPSI
PM an email address and tell me what your replacing, bumper cover or fender, and I'll email the service manual segments for you.
Old Dec 1, 2010 | 07:07 AM
dougbfresh's Avatar
dougbfresh
Looks like the fender to bumper cover bracket. I used a LONG 1/4" extension, put a little grease on the socket to hold the nut and Viola-got it easily.
Old Dec 1, 2010 | 10:42 AM
beaners's Avatar
beaners
That is what I dont understand> the original had studs for nuts the new one doesnt. dont quite understand. Cant get my hand in there to nut and bolt it..
Old Dec 1, 2010 | 10:44 AM
beaners's Avatar
beaners
Sent a pm ! just dont quite get it??? Thanks
Old Dec 1, 2010 | 10:51 AM
dougbfresh's Avatar
dougbfresh
Try a stove bolt.
Old Dec 1, 2010 | 11:06 AM
Sinking's Avatar
Sinking
Can you tack weld some bolts in place?
Old Dec 1, 2010 | 11:58 AM
bumble-z's Avatar
bumble-z
When OP posted picture, that was my first thoughts. Weld in threaded stock/bolt, minus head. Both being of the same length, thread size as original.
Are we missing something here?
Old Dec 1, 2010 | 01:32 PM
dougbfresh's Avatar
dougbfresh
Seems like a 25+ year body guy could figure this out.
Old Dec 1, 2010 | 03:59 PM
beaners's Avatar
beaners
never took it apart. Seems the one with studs goes behind fender and cover bolts to it(makes sense) the one without studs is made to slide over inner cover. Maybe cage nuts then? Must be some design change? the dealer doesnt know anything about vettes (the one in my area) Been doing this along time but this is my first new body style. I am amazed the way the inner (fiberglass part) just floats on the frame with no bolt or stud for alignment) Just wanted to prefit it all before I put the glue in. This car has been a pain from the get go... Just wished I could have taken it apart. Front was wiped off. Just was hoping someone might have been thru it thats all. Going to try the cage nuts on that piece with no studs and bolt up from the bottom. Thanks for any and all help..Jay
Tried to upload pics but photobucket is down
Old Dec 1, 2010 | 08:52 PM
beaners's Avatar
beaners
http://i936.photobucket.com/albums/a...t/DSC03138.jpg
http://i936.photobucket.com/albums/a...DSC03137-1.jpg
Old Dec 1, 2010 | 09:54 PM
FRCTony's Avatar
FRCTony
I am assuming you are trying to bolt the front clip together, and (set)glue new wheel wells in. No clue how the wheel wells should be set, but I'm pretty sure it is in the collision manual.
I don't think you can mount the fenders until the wheel wells are set.
Old Dec 2, 2010 | 09:43 AM
beaners's Avatar
beaners
have it all on there(minus glue) Everything seems to fit fine. Just wanted to check the front cove ras well. Then ran into this bracket prob. Give it another shot this am...
To Help????
