Question on torque tube
Old Dec 1, 2010 | 09:30 AM
dogboy's Avatar
dogboy
Default Question on torque tube
Can I use an 03 torque tube on an 00 coupe . I believe the older ones had 10mm vs the newer 12mm bolts.
Old Dec 1, 2010 | 02:02 PM
All_Motor_C5LS6's Avatar
All_Motor_C5LS6
Yes
Old Dec 1, 2010 | 02:03 PM
Toxiclemonade's Avatar
Toxiclemonade
You should be. The 10mm vs. the 12mm. bolts deal with the bushings which has nothing to do with connectiong to the tranny or the clutch. Good luck.
Old Dec 1, 2010 | 08:21 PM
dogboy's Avatar
dogboy
Great , Thanks all!
Old Dec 2, 2010 | 09:11 AM
clif's Avatar
clif
St. Jude Donor '09-'10
I even upgraded my 99 torque tube to have 12MM bolts instead of the 10MM that it came with.
To Question on torque tube
