L92 heads on a LS1 ???
Old Dec 3, 2010 | 01:32 PM
R6cowboy's Avatar
R6cowboy
Default L92 heads on a LS1 ???
Can the L92 heads from the LS3 bolt onto a LS1? If so, what needs to be done besides boring the cylinders to a 4.0" minimum?
Old Dec 3, 2010 | 02:04 PM
tblu92's Avatar
tblu92
St. Jude Donor '13-'14-'15
Can't be done----From what I've ben told by machine shops or at least not reccomended to bore a LS1/LS6 to 4.0----
HOWEVER--Mast Motorsports makes their own version of the L92 head that will fit on s stock bored LS1/LS6
You will need a L92 intake manifold-- A new style LS3 or L92 throttle body--A T-Body pigtail adapter-- A new fuel rail that fits--May also need different injectors--not sure but if so injector pigtail adapters as well---
Old Dec 3, 2010 | 04:31 PM
R6cowboy's Avatar
R6cowboy
Just realized it would need to be bored 1/8". You're right, not happening.
Old Dec 3, 2010 | 07:01 PM
AU N EGL's Avatar
AU N EGL
Even if you could, WHY? 243 heads are far better heads.
Old Dec 3, 2010 | 07:07 PM
WKMCD's Avatar
WKMCD
Depends on how you use them.
Too much head to a 346 unless you put a sheet metal or single plane intake on it and rev the pi$$ out of it..
Old Dec 4, 2010 | 08:57 AM
AU N EGL's Avatar
AU N EGL
Kevin is right
Depends on the builder and use as in your car.
Old Dec 4, 2010 | 12:33 PM
tblu92's Avatar
tblu92
I agree--- the L92 big port heads wouldn't make more power unless in an engine with bigger cubes OR an engine comnsistantly ran above 6800 probably 7000---
Old Dec 4, 2010 | 02:20 PM
R6cowboy's Avatar
R6cowboy
In what way do you mean 243's are far better heads. Just curious on your thoughts.
Old Dec 4, 2010 | 02:41 PM
CamminC5's Avatar
CamminC5
St. Jude Donor '15-'16-'17-'18
Better for your application. You can't go wrong with a set of ported 243's...
Old Dec 16, 2010 | 12:29 PM
rustyguns's Avatar
rustyguns
he prob wants them because the L92's are cheaper than 243 or 799's
Old Dec 16, 2010 | 03:16 PM
WKMCD's Avatar
WKMCD
Something else to add here. You can't bore a 346 to 4". You can however sleeve them. Getting an LS2 block and sleeving it would be a much better option. THEN - you can run the L92 heads which IMHO are a very good choice but only if cammed properly.
Old Dec 16, 2010 | 03:19 PM
AU N EGL's Avatar
AU N EGL
With the LS1 or LS6 the smaller chambers of the 243 heads make more power.
There are a few builders that are putting 243 heads on the LS3s and getter better results then the L92 heads.
again depends on your application.
Some times it may be best to do nothing then do a cheap build.
Old Dec 16, 2010 | 03:25 PM
WKMCD's Avatar
WKMCD
There are a lot of builders that still don't know how to cam them
Old Dec 16, 2010 | 03:34 PM
AU N EGL's Avatar
AU N EGL
That is so true Kevin
Then we have also seen many LS3s go bang this summer in racing.
Oiling issues are the big one and the heads were issues in others.
Heck one guy went through THREE LS3s in a week
Old Dec 16, 2010 | 05:34 PM
WKMCD's Avatar
WKMCD
That big intake valve is pretty heavy. I don't think I'd road course these heads unless I spent some real coin lightening up the intake valve and making sure my valve control was perfect. For some reason GM left some flaws for running hard in both the stock block LS3 and 7. LS7's like to pop the block.
Old Dec 16, 2010 | 05:48 PM
AU N EGL's Avatar
AU N EGL
Now that you mention it.
Flaming C6Z06
Old Dec 19, 2010 | 02:08 PM
R6cowboy's Avatar
R6cowboy
Not quite. I was asking out of curiosity. I'm new to the LS-x and just trying to learn differences between LS engines. I read a couple articles on the L92 heads that specified how well they flowed and the power potential the heads offer. The more I read about LS engines the more questions I come up with that have nothing to do with my car/application. I just like to know facts.
The heads I'm actually going with for my application are a set of Total Engine Airflow LS1 Stage 1.5 heads, and a Camshaft Innovations custom cam. Yes, I heavily considered the 243 casting heads but for what I want the TEA 241 stage 1.5 heads are great. In the mean time, if I do happen to find a set of used stock 243/799 heads for a good price I would pick them up and send them off to TEA.
I guess I should have added this to the original post, lol.
To L92 heads on a LS1 ???
