Magnesteer?
Old Dec 6, 2010 | 03:55 PM
lwise4's Avatar
lwise4
Default Magnesteer?
I posted this problem right after I bought this 03 Z06 in July. Two Dealers later three trips, and a few bucks, I still have a hard steering problem. Pump pressure is OK, new fluid installed, and no codes are set. The Tech II detected no problems!
Today it is in the twenties and I ran an errand. I came out after the car had sat two hours and when I backed out of a slightly downhill parking spot, I felt a shudder in the front when I turned to back out. It felt like the tire was hitting the frame! The wheel was only turned slightly so it was not hitting. ps, The front tires are original so they are the correct size.
I then stopped by a store and when I came out and backed out of the parking spot I got the same shudder. I drove home and in the garage, turned the wheel full left and then right and was able to get a shudder although not as bad as the first time. The car has always been harder to steer than normal but the shudder is a new malady!
Too cold to fool with it now, but looking for idea's. The car has less than 17K miles on it.
Old Dec 6, 2010 | 08:48 PM
PEERPSI's Avatar
PEERPSI
Tires were cold and not gripping well enough to cope with the torque coming from out back. I've had numerous sports cars and was quite surprised when it happened with my newly acquired Vette.
Old Dec 7, 2010 | 05:08 PM
lwise4's Avatar
lwise4
I don't see what that has to do with just backing out of a parking space? The groaning will happen sitting still and turning the wheel although not all of the time.
Jacked it up today and checked all around the steering rack. I had convinced myself that the car did not have Magnesteer as I could not locate a wire running to the steering rack. I finally found it and recorded 2.7 ohms across the vss. The manual says 1.8 to 3.2. As it stands now, I suspect the ECBM.
This is my fourth C5 and the only one that steers hard!
Old Dec 8, 2010 | 03:29 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Have someone turn the steering full left and full right while you examine the pump pulley and see if its slipping on the pump shaft or if the belt is slipping on the pulley.
Try and turn the steering wheel at different speeds. SLOW and FAST.. and see if that makes a difference.
BC
Old Dec 8, 2010 | 03:44 PM
lwise4's Avatar
lwise4
BC
I had the car in to the Dealer back in August with the complaint that it was not steering right. Then the problem was that the steering was hard all of the time and did not vary with speed. The groaning and shudder was not occuring at that time.
They put the Tech II on it and found nothing wrong. I then had them pressure test the pump and it passed with flying colors. The tech mentioned that the belt was starting to fray so I had it replaced. At the same time, they changed the fluid in the system and put in the latest GM "cold weather" fluid. After this work was done it still steered harder than normal, no change!
This week the temp's dropped into the teens and then the shudder showed up. It is very noticeable when turning the wheel pulling out of a parking space. I called the Dealer today and He wants me to bring the car back. We will see?
To Magnesteer?
