Check engine light
Old Dec 17, 2010 | 01:54 AM
ant21b's Avatar
ant21b
Default Check engine light
My 2002 has the check engine light on continuosly when driving. It has a rough idle like it wants to die but at 10-20 mph and above it smooths out.
Please advise.
Old Dec 17, 2010 | 02:21 AM
manley845's Avatar
manley845
Please advise.
What are the codes?
Old Dec 17, 2010 | 08:56 AM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
I agree, check and post the codes. First thought is an air leak at the air-bridge or the PCV line to the intake.
Old Dec 17, 2010 | 09:52 AM
ant21b's Avatar
ant21b
10 PCM
P0171 HC
P0174 HC
28 TCS
c1221 h
c1222 h
c1226 h
c1248 h
c1281 h
c1287 h
c1288 h
60 IPC
b0521 h
A6 SCM
b0851 h
b2605 h
Old Dec 17, 2010 | 10:00 AM
dougbfresh's Avatar
dougbfresh
Search on the C(urrent) codes like I did:
http://forums.corvetteforum.com/c5-t...howing-up.html
is just one posting on the subject.
Clear them all and see what returns.
Old Dec 17, 2010 | 10:24 AM
ant21b's Avatar
ant21b
The check engine light has never come on before in the 6 years I have owned the car. The car sat about 2 days before I drove it andthis happened. Does letting the car sit without being driven cause a malfunction in the air seals or the pcv lines?
Old Dec 17, 2010 | 10:26 AM
dougbfresh's Avatar
dougbfresh
Coincidence.
Old Dec 17, 2010 | 10:30 AM
lucky131969's Avatar
lucky131969
No. You will have to peform a physical inspection....as already suggested.
Old Dec 17, 2010 | 10:33 AM
Bull_in_a_china_shop's Avatar
Things like corroded grounds on the car can also freak out multiple systems - let us know what comes back after being cleared
Old Dec 17, 2010 | 10:38 AM
manley845's Avatar
manley845
Any other symptoms? Such as reduced mileage, black smoke from tailpipes, coolant temp reading lower than usual, anything?
It's odd to think that the MAF sensor would dirty, most filtration systems prevent this, even oiled filters. It could be a bad MAF sensor perhaps. Tap the MAF with the handle of a screwdriver while the engine is idling and see if it stumbles.
Like mentioned above, do physical inspection too. It could be that a vacuum hose has a crack or came loose.
Keep us posted
Old Dec 17, 2010 | 11:50 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Unless you dig in and start systematically looking for air leaks. We can GUESS what it is all week long without point out the exact problem area.. That’s the FIRST and most logical place to start.
Go and look for any place that allows un-metered air into the engine. Any ducting between the MAF and TB and ALL the vacuum lines and fittings. Especially the PVC system hoses and fittings.
Old Dec 17, 2010 | 11:56 AM
ant21b's Avatar
ant21b
I heard a hissing noise under the hood. Investigated and it turned out that of two my hoses and the rubber boot on the alternator wire were all chewed up by mice or something. Had some trees removed this week along with bushes I guess some mice had their home disurbed. The car usually sits in the driveway and it sat for two days dont know how long this has been going on though. Taped up vacum hose going to master cylinder and no more codes drives fine now. The chewing looks nasty though on those two hoses.
Old Dec 17, 2010 | 01:53 PM
dgrant3830's Avatar
dgrant3830
Tape will eventually come off. Replace the hose(s).
Old Dec 17, 2010 | 01:54 PM
lucky131969
Guess they were pissed about being displaced from their home. Tape is ok for a temp fix, but not a permanent fix.
Old Dec 17, 2010 | 05:58 PM
ant21b's Avatar
ant21b
Only 1 of the two hoses is available from the dealer. GM has discontinued the other one.
Old Dec 17, 2010 | 06:48 PM
manley845's Avatar
manley845
Just get creative. Any preshaped coolant hose will work, or if need be, just use a straight piece of fuel line (not sure what size hose you're talking about). The brake booster hose is 3/8" though.
Glad you found the problem
Old Dec 19, 2010 | 07:34 PM
02koolC5's Avatar
02koolC5
i also have a check engine light on....10-pcm code 1416 HC
To Check engine light
