How do I calculate restrictor sizes ?
Old Apr 8, 2002 | 07:45 AM
vette.se's Avatar
vette.se
Default How do I calculate restrictor sizes ?
Please take a look at my post in the racing section:
http://forums.corvetteforum.com/zerothread?id=274516
Thanks !
Old Apr 8, 2002 | 12:36 PM
vette.se's Avatar
vette.se
Default Re: How do I calculate restrictor sizes ? (seanr)
ttt
Old Apr 8, 2002 | 03:18 PM
vette.se's Avatar
vette.se
Come on someone must know the physics behind this :yesnod:
In most racing series they use a restrictor at a given diameter to limit the power output. They must have used some kind of formula to calculate the diameter !
As an example: The Vipers in the European GT series uses two 34.1mm restrictors to limit the power to 600hp, without they produce 800hp.
The Street Corvette has only one airintake/throttlebody. Could it be as simple as if I would use one 34.1mm restrictor I would get 300hp ?
Using the above example using a 55.2mm restrictor would give me a maximum of 485hp but it can't be this simple or ....
To How do I calculate restrictor sizes ?
