Speedo Calibration
Old Dec 23, 2010 | 08:59 AM
C5Natie's Avatar
C5Natie
Default Speedo Calibration
Hey guys, Im going from 295/35r18 in the rear to 315/30r18 tires . These will be around 1/2in shorter. Will that warrant the need to calibrate my speedo? Thnx.
Btw, for now, my fronts are 25.6-7in tall while the rears will be 25.5in tall. Will it be noticeable?
Old Dec 23, 2010 | 09:30 AM
k0ts's Avatar
k0ts
Here's a calculator...
http://www.miata.net/garage/tirecalc.html
Old Dec 23, 2010 | 11:38 AM
rebelheart's Avatar
rebelheart
I think you will have traction control problems with that combo as there isnt enough difference in size between front and back.
Old Dec 23, 2010 | 02:05 PM
Jnape's Avatar
Jnape
100% for sure. A/H will be activated on every corner.
Old Dec 23, 2010 | 10:51 PM
CaliforniaJack's Avatar
CaliforniaJack
Default Speedo calibration
Since your tires heat up and expand, monitor the tire pressures (on your drivers info screen). When they stabilize (after a half hour), drive on a straight road and hold your speed steady. Read your TRUE speed on a portable GPS unit and compare the two. You should repeat this at various speeds(50, 75,100....). It helps to have a passenger read the GPS true speed while you concentrate on maintaining a steady speed.
Old Dec 24, 2010 | 01:02 PM
C5Natie's Avatar
C5Natie
Than guys. Im looking at 255/35r18 for the front now so the rears will be 1/2in taller than the fronts. I turn off the tc a lot but I still use it when it rains and I dont wanna see service tc codes all the time. Thnx.
Old Dec 25, 2010 | 02:52 PM
tblu92's Avatar
tblu92
St. Jude Donor '13-'14-'15
A 1/2" shorter tire on the rear won't affect the speedo that much--You will be going a little slower than what the speedo reads without correcting it--On a 6 speed there isn't a need to do anything else but on an A4 a small shift-point correction will help it shift at the proper times
HOWEVER---altering the split between the front heights and rears different that the stock 1" differnence, will affect the traction control and more importantly the ABS brakes--The ABS may NOT work---This is NOT correctable---I would try to keep the 1" split
Old Dec 27, 2010 | 06:06 PM
C5Natie's Avatar
C5Natie
Hmm Ive never heard that before since I didnt think abs was affected by a difference in wheel speeds. thing is Ive had a 1/2in difference for years. 245/40r18 are like 25.6in tall and 295/35r18 are 26.1in tall. So if that were true I wouldve had tc and abs problems a long time ago yet both systems have been perfectly fine with no issues ever.
To Speedo Calibration
