Using Front Calipers on Rears???
Old Apr 9, 2002 | 01:16 PM
Mean Green's Avatar
Mean Green
CI III & IV Vote Ho
CI II, III, IV & V Vet
CI IV Bracket Champ
St. Jude Donor '03-'04
Default Re: Using Front Calipers on Rears (Mean Green 2000)
someone on here has to be running this setup....:cheers:
Old Apr 9, 2002 | 04:00 PM
jw38's Avatar
jw38
St. Jude Donor '14,'18,'21
I was wondering the same thing because I just purchased the new Eradispeeds and the rear calipers look TINY against the new rotors. I'm going to ask someone at LAPD...since I bought the rotors there.
:cheers: :flag
Old Apr 9, 2002 | 04:09 PM
jw38's Avatar
jw38
Just got a reply from Shawn at LAPD (man they're fast!). He says the Eradispeeds are too new and he doesn't know of anyone who has done the mod. Since I have an extra set of front calipers, I may TRY the set-up when I install the rotors. Even if they do fit, I probably won't drive the car...I'm afraid of ruining the new rotors! :cheers: :flag
Old Apr 9, 2002 | 05:45 PM
jw38's Avatar
jw38
I just received a call from Rick at Baer. I had sent him and email asking about using front calipers on the rear wheels. The answer he gave me is a definate NO!! Basically, the bore size of the front caliper is much larger than the rear and as brake bias is extremely important, using front calipers on the rear will upset the bias, causing a potentially dangerous situation. Rick said that this could cause problems with the ABS trying to compensate for the increased rear bias and, in racing situations, could cause the rear end to swing around. The bottom line is this: Baer designed and manufactured the new Eradispeeds mainly for cosmetic reasons. Many C5 owners don't like the fact that the stock front rotors are considerably larger than rears. That, compounded with the fact that the rear wheels are larger than the fronts, drove the request to manufactur larger rear rotors...to match the front rotors. I hope this helps!! :cheers: :cheers: :cheers:
Old Apr 9, 2002 | 05:46 PM
Evil-Twin's Avatar
Evil-Twin
Mean: there was a guy here last year... I took note to his settup.. I cant remember his name but .. he had a red vert.. with a red hard top.. and he had neon in the front fender vent.. he did put front calibers on the back..with larger rotors.. but he lost his emergency brake.. with the new eradispeed rears with the emergency hub built in.. it should be a no brainer..the backs are 14 inch.. the fronts are alittle smaller..but in my opinion this should work.. it is easy enough to see..Shawn or nate must have a front caliper around.. and having the corvette logo on the front and rear is cool.. and you will still be able to use the E brake..
Old Apr 9, 2002 | 07:30 PM
Mean Green's Avatar
Mean Green
CI III & IV Vote Ho
CI IV Bracket Champ
Default Re: Using Front Calipers on Rears (Evil-Twin)
thanks for the info guys...I still need to follow up with Nate and ask about his conversion kit :)
Old Apr 9, 2002 | 07:41 PM
Z11409's Avatar
Z11409
Fronts bolt right on the rear--But you give up the handbrake and you need to install a proportioning valve in main brake line to rear brakes.
Old Apr 9, 2002 | 08:41 PM
Mean Green's Avatar
Mean Green
CI III & IV Vote Ho
CI IV Bracket Champ
Default Re: Using Front Calipers on Rears (Z11409)
anyway you can email me with more specific details, if you have 'em :D
Old Apr 11, 2002 | 03:31 AM
EB_Z06's Avatar
EB_Z06
Mean Green,
Have you talked to Nate? Like Evil-Twin said, this should be possible...
Old Apr 14, 2002 | 02:38 AM
GTP's Avatar
GTP
Default Re: Using Front Calipers on Rears (EB_Z06)
Just thought I would add to this conversation. The rear Eradispeed 14 inch rotors probably won't work with the front calipers mounted on the rear so you have 2 choices. You can buy stock size front rotors for the rear and lose the E-brake or you can try convicing BAER to install a stock size front rotor on the 14inch eradispeed hat and therefor maintain your emergency brake.
Aaron Lephart
Old Apr 14, 2002 | 10:38 AM
Mean Green's Avatar
Mean Green
CI III & IV Vote Ho
CI IV Bracket Champ
Default Re: Using Front Calipers on Rears (GTP)
haven't talked to Nate yet, but I will later this week :)
Aaron Lephart
thanks man, I'm trying to figure out exactly what to do now, I'll be checking on my order with Shawn on Monday as well.....questions, questions, questions :eek:
