camshaft overlap and driveability
If so did he select the cam?
Ahhhhh! I knew there was something familiar bout this
Just did a little searching.What are Tony comments regarding this cam choice & your drivability concerns?
Are you HPT capable?
More exhaust then intake should provide more torque
may want to go smaller to get low rpm livability.
228 / 232 .588/.595 112+2
I'm extremely interested in this as I have just finished my 416 with a slightly larger cam......& I don't want no cranky ***** Phk'r.
I'm curious if all the little tuning tricks are exhausted, there are many.
some times it is very cool to have lots of High RPM HP, but if you never or seldom drive in that RPM range, why go there? For the bar / bench racing bragging rights?
I'm helping a friend build his engine after a rod bearing problem and I know he wants it to drive very nice. I think we will be staying around 218-220 on the intake on stock cube or just a touch bigger if he decides to go 383. Nice smooth power under the curve.
I am for sure not interested in an SD tune. The car is located in Indianapolis, weather conditions can vary from 40 degrees F to 90 degrees F and the humidity can swing wildly as well; I do not tune, and want the car to simply be a “turn the key and go” and not have to worry about weather conditions and tuning. Everyone has told me I should stay with the MAF tune. The car is not a "daily driver", but it spends 99.9% of its time cruising around town, stop light to stop light during the spring/summer/fall months when the weather is nice. I drive to work every now and then, I take the wife out to dinner often in it, and we go shopping in it. So it is every bit an in town, parking lot, stop sign warrior, with the occasional "spirited" romp on an on ramp, passing a guy on the interstate, or doing a 1-2-3 gear burnout to put a smile on the little kids face in the next lane kind of thing. So as you can imagine, the car spends most of its life below 2500rpm (I have 3.90's in the car - Z06 tranny - so I cruise down the road between 1700 and 2200rpm). I have spent as much as I am willing to spend (money and time wise) having the car tuned (two well known tuners have touched the car and they got it as good as they could get, and both of them told me, "you are not going to get the kind of low RPM driveability you are looking for with that size of cam in the car". I am gladly willing to drop 20HP peak to gain low rpm driveability, as I have no need to impress anyone “with a number”. I like torque, low rpm torque and instant throttle response at any rpm (ex road racer mentality).
The car has an RPS twin carbon clutch in it. GREAT clutch, very easy to maneuver in tight parking spaces, but it is VERY light weight (clutch/flywheel combo), and I think that light mass coupled with the large cam overlap just exacerbates my low rpm issues.
I have pretty much decided that I am going to change the cam, but like I stated, I simply don’t know enough about camshafts to make a decision on my own, and I don’t want to take one guys advice, I like getting several different options, different perspectives, points of view, etc. Is going from 14 degrees of overlap to 4 degrees of overlap a big enough change to significantly increase my low rpm driveability and not completely choke the motor off? Is it too much? I don’t know, hence my question. FWIW – my car makes 540RWHP and 500RWTQ right now. I would be tickled pink if I can gain a bunch of low rpm driveability and still make 525RWHP and 490-500RWTQ.
Thanks again everyone for taking the time in trying to provide me with suggestions.
i'm actually looking forward to my friends small cam setup just to see how things turn out and how nice it drives.
I'm HPT, I don't think you can go wrong with either software. The learning curve is steep so I would make your purchasing decision based on the education material available as well as support. Maybe a mentor.
I started self tuning to try & correct some of the very issue's being discussed in this thread. Many things are a test & tune, some work some don't, you have to try. Difficult to pay a tuner for the hours that it takes for that perfect tune. Resilience
