oil catch can recomendation
Old Jan 3, 2011 | 02:32 PM
machz800ps's Avatar
machz800ps
Default oil catch can recomendation
Am planing on installing a oil catch can on my 04 z, engine is stock w/ a vararam and a set of lg long tubes (may do a cam down the road) are all brands pretty much the same or is there a specific one i should buy
Thanks in advance
Steve
Old Jan 3, 2011 | 02:42 PM
hotwheels57's Avatar
hotwheels57
ELITE ENGINEERING USA (site supporting vendor)...
http://www.eliteengineeringusa.com/Catch_Can.html
They've got lots of other items that will get your attention as well.
Old Jan 3, 2011 | 07:32 PM
Dave68's Avatar
Dave68
They are definitely NOT all the same.....
http://www.conceptualpolymer.com/PCV...oval%20102.pdf
...for comparisons.
Old Jan 3, 2011 | 07:47 PM
DaBoz's Avatar
DaBoz
...for comparisons.
Dave, of the currently available catch cans out there, which would you recommend??
Old Jan 4, 2011 | 12:18 AM
Dave68's Avatar
Dave68
Gene,
PM sent
Dave
Old Jan 4, 2011 | 12:44 AM
T.J.'s Avatar
T.J.
[QUOTE=hotwheels57;1576403418]ELITE ENGINEERING USA (site supporting vendor)...
Old Jan 4, 2011 | 07:16 AM
Must_Have_Z's Avatar
Must_Have_Z
I chose Elite Engineering's version:
Old Jan 4, 2011 | 09:22 AM
machz800ps's Avatar
machz800ps
Thank you !!!!
Old Jan 4, 2011 | 09:24 AM
DeeGee's Avatar
DeeGee
Another Elite Engineering fan here
Old Jan 4, 2011 | 10:15 AM
Dave68's Avatar
Dave68
Without going into too much detail (the white paper does more of that), Here're a couple of tips:
1. Keep the catch can away from heat. The hotter the blowby gasses and entrained oil droplets, as well as the surfaces they contact, the more likely they are to squirm past the filter media. Synthetic oil is especially tough to trap.
2. Make sure the routing of blowby gasses is such that the last thing the air "sees" is the filter media. Many catch cans route the air through the media first, and then expose it to sloshing oil before sending it on to the intake manifold - not good!
Dave
Old Jan 4, 2011 | 01:07 PM
Chevy Guy's Avatar
Chevy Guy
Good to see you installed it properly and used the OEM PCV connection!!
I see so many people do it wrong by replacing all the of the PCV hose with the new hose that comes with the can. Then they are amazed at how much oil is in their can.
Old Jan 4, 2011 | 10:21 PM
rws.1's Avatar
rws.1
Chip at CCA
Old Jan 5, 2011 | 01:38 AM
Milan's Avatar
Milan
If you decide to buy the Elite Engineering can in black, I will sell you mine, it's brand new. I can't use it because there is no room for it with a centrifugal blower
Old Jan 5, 2011 | 04:23 AM
Fat Finger's Avatar
Fat Finger
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
Without going into too much detail (the white paper does more of that)...
No joke! That's quite a write-up! Very interesting.
You've gotta admit though, that the massive catch cans look like they can do much more than that tiny little glass filter. After all, it's always said that Americans like big things!
Thanks for the education.
Old Jan 5, 2011 | 10:26 AM
Dave68's Avatar
Dave68
You're welcome. Designing an oil trap does go way beyond stuffing some media in a tube. The velocity of gasses passing through the filter is somewhat critical - too large the filter area = lower velocity of the blowby gasses. At some velocity, the oil droplets easily work their way around the media. So, for catch can filters, size matters and bigger is not necessarily better. Too high of a velocity will encourage droplets to be "retrained" into the airstream - not good, either.
As far as the can size goes: Having a large can for the sole reason of not having to empty the oil can be self-defeating in that blowby gasses that have to pass by a large volume of sloshing oil are bound to pick up some of that oil. This is especially true of large diameter catch cans.
Old Jan 6, 2011 | 06:04 PM
Elite Engineering's Avatar
Elite Engineering
Supporting Vendor
St. jude Donor '14
To oil catch can recomendation
