Cam 101.... Make up Session
Old Jan 6, 2011 | 04:32 PM
JanCorvette's Avatar
JanCorvette
Default Cam 101.... Make up Session
So i missed CAM 101 at School. I need to better understand CAMS to make the right decision. Could somebody explain the difference b/w 224/230 and 230/224? I know that reverse split give higher torque but why? What is the 112,114,116 mean? Which is better? Durations?
From what i have read. I feel that a 224/230 cam will be good for me. Its a good street cam, mild idle, would yield 45-50rwhp. I have a C5 6 speed, Halltech intake, headers, catback, no cats, diablo. Stock gears and stock heads. In the future may installed a LS6 manifold and some ported 243 heads. Aim is 420rwhp.
Any help?
Old Jan 6, 2011 | 04:34 PM
lucky131969's Avatar
lucky131969
Any help?
http://www.hotrod.com/techarticles/1...aft/index.html
http://www.chevyhiperformance.com/te...ics/index.html
Old Jan 6, 2011 | 04:50 PM
JanCorvette
thanx for the cliff notes
Old Jan 6, 2011 | 04:52 PM
lucky131969
You read those articles quickly. I guess you are farther along, then you give yourself credit for.
Old Jan 6, 2011 | 06:42 PM
AU N EGL's Avatar
AU N EGL
Cam Guide 101 - Click HERE
Old Jan 6, 2011 | 10:35 PM
_r2h's Avatar
_r2h
Good reads right there.
Old Jan 7, 2011 | 05:23 AM
vettenuts's Avatar
vettenuts
David Vizard also wrote a good book on cams. It focuses on the small block but the basics are the same. I personally wouldn't run a reverse split cam on these motors.
Old Jan 7, 2011 | 01:44 PM
zeevette's Avatar
zeevette
The LS seems to like more exhaust duration than intake. The size you're talking about (224/230) is one that you can get great results from. The LSA affects the idle characteristics, so if you want a nice lope, stick with a 112 or lower. There's a cam guru over at ls1tech.com name of Patrick G. that's spent alot of time dissecting cam designs. He can even design a cam that'll fit your needs better, and you needn't be afraid of custom grinds. Good luck, and your goal is easily attainable.
To Cam 101.... Make up Session
