Automatic headlight issue?
Jan 9, 2011 | 06:40 PM
7th Gear
I have a 99 conv. When I use the DIC to change from auto to manual it will not change over? Has anyone heard of this and/or knows the fix?
Jan 9, 2011 | 06:45 PM
Cruise-In VIII Veteran
I might be wrong, but I think that cars made for some countries it can't be changed. They are always on auto.
Jan 9, 2011 | 07:00 PM
Quote:
Originally Posted by
navy99vert
I believe Canada cars are stuck with the option.
Jan 10, 2011 | 01:32 AM
GM Tech 2 can turn it off. Where are you located? Maybe you can find someone where you live that has one.
Jan 10, 2011 | 08:17 AM
Wounded Warrior Escort '11
I'm was having this issue myself. Let me ask, are your low beams turning on or sometimes not coming on? Are they coming up or staying down? If they are staying down, are they actually illuminated? Depending on your options, there are only three main items. The headlamp switch itself which has a fairly high failure rate, the headlamp control module which raises or lowers the lights and finally the headlamp motors.
Jan 10, 2011 | 07:08 PM
7th Gear
striper, I'm located in York PA, hopefully someone on this forum knows were I can hookup with someone local. I have heard of this also.
Jan 10, 2011 | 07:14 PM
7th Gear
dgrant3830, My headlights are working as they should. The only issue is I can not turn off automatic and be in manual mode.
Jan 10, 2011 | 09:57 PM
Then you'll need to find out if you have a Canadian car.
Jan 13, 2011 | 06:52 AM
Car
Jan 13, 2011 | 10:10 AM
I'll suggest that you send an email to Gene Culley and give him your VIN# as if anyone can tell you, its probably him.
Jan 13, 2011 | 08:13 PM
7th Gear
I checked the VIN and found that this started out on the west coast (California), then New Mexico, Michigan,and finally Pennsylvania.
Jan 13, 2011 | 09:22 PM
If that is the case, then I"ll suspect the headlamp switch is having issues. Its a high failure item.
