I am trying to replace the radiator on my 1998 and have disconnected the wiring harness from the fan shround but cannot get the shroud to seperate from the radiator. Are there bolts attaching this or how do I do this. Thanks
You need to lift up on the A/C condenser about 1 1/2" to get the tabs to clear the slots on the rad. After you lift up just lower the condenser down while pushing it a little forward so it won't go back into the slots.
I'm fed up. Are you people all acrobatics? I'm pretty nimble I think. The Fan shroud is almost impossible to remove/insert. There are a million hoses with almost 0 space to access. Half the work has to be done under the car. The shroud wont budge unless you almost bend the damn thing. Next time: drop it off at the mech, let him deal with ******** 'new' car space constraints, spend day doing something pleasant. I enjoyed fixing cars 20 years ago when there was ample space. In the meantime, I'm done with this.
Disconnect the negative battery cable.
Raise the vehicle and support.
Drain the coolant.
Lower the vehicle.
Remove the radiator upper support.
Remove the electrical connectors and harness from the fan shroud.
Remove the fan shroud from the radiator.
Remove the radiator inlet and outlet hoses from the radiator.
Remove the automatic transmission cooler lines from the radiator (if equipped).
IMPORTANT: It is not necessary to disconnect the A/C lines from the condenser.
Remove the condenser from the radiator and position it forward.
Remove the radiator from the vehicle.
INSTALLATION PROCEDURE
Install the radiator.
Install the condenser into the four retaining tabs on the radiator.
Install the automatic transmission cooler lines to the radiator (if equipped).
Install the radiator inlet and outlet hoses to the radiator.
Install the fan shroud into the four retaining tabs on the radiator.
Install the electrical connectors and harness to the fan shrouds.
Install the radiator upper support.
Lower the Vehicle.
Connect the negative battery cable.
Tighten the negative battery cable bolt to 15 Nm (11 ft. lbs.).
Program the transmitter.
I was reading that thread and saw that one of them was from me over a year ago. Makes me remember, last year someone send me a PM about a thread I posted over 10 years ago about replacing a blower motor on a C3, I had clear the cob webs on that one.
