Head light pop o[ issue.
Old Mar 25, 2012 | 06:04 PM
J Wagner's Avatar
J Wagner
Default Head light pop o[ issue.
(99 Corvette) When I turn the headlight switch on sometimes the headlight do not com up or on. After 2, 3 or a few more tries, the come up. Before I go replacing a $250 turning signal arm and headlight switch, is there something I should check?
Old Mar 25, 2012 | 06:46 PM
ryrob's Avatar
ryrob
Yeah you need to do a quick search on here before anything else. Very doubtful it's the headlight switch based on my own experience.
Old Mar 26, 2012 | 07:42 AM
egrand333's Avatar
egrand333
I just replaced the turn signal/headlight switch to try and fix the exact problem that you describe.(except that my lights would come on but not pop up) It did not fix the problem. Pretty sure it is the "headlight control module". If I had read the other posts on this subject more carefully I would have known that if the headlights come on but do not pop up it is probably not the turn signal switch. If you find that you need to replace the turn signal arm an A/C Delco can be bought for $150-$180 if you shop around.
Old Mar 26, 2012 | 01:37 PM
Vettmann17's Avatar
Vettmann17
Do you have HID's installed or are the headlights stock?
Old Mar 26, 2012 | 09:20 PM
J Wagner's Avatar
J Wagner
VETTEMAN: They are stock lights.
EGRAND333: I will check again, but I don't think the lights come on when the don't pop up.
Thanks for the info guys.
Old Mar 27, 2012 | 03:04 AM
DeeGee's Avatar
DeeGee
The guys are correct. Troubleshooting headlight problems can be guesswork without being able to put a DMM on the car. The T/S switch, hazard switch or headlight modules are the normal problems.
I have the troubleshooting guide. PM me with your e mail if you'd like a copy.
Old Mar 27, 2012 | 03:07 AM
DeeGee's Avatar
DeeGee
Working through the guide using your symptoms it comes up with this:
Are the headlamp doors closed at all times? YES
1. Remove the right hand headlamp assembly.
2. Disconnect the control module connectors C1 and C2 to the actuator for the headlamp opening door.
3. Turn the headlamps ON.
4. Connect a test lamp between the headlamps ON input circuit and a known good ground at connector C1.
Does the test lamp illuminate?
Yes or No?
Yes:
Inspect the harness connector for headlamp opening door actuator control module for a poor connection.
No:
Repair a poor connector or an open in the ground circuit.
Old Mar 27, 2012 | 06:10 AM
trjohn57's Avatar
trjohn57
8th Gear
I also have a headlamp door problem in my 77. Doors won't pop up and I do have vacuum. Wish me luck.
Old Mar 28, 2012 | 09:24 PM
J Wagner's Avatar
J Wagner
EGRAND333:You are correct. The lights do come on and the lamps do not pop up. Accord to you I should look to the "head lamp control module." Do others agree? Thanks for the help.
Old Mar 30, 2012 | 07:46 PM
trjohn57's Avatar
trjohn57
8th Gear
I'm still waiting to see the answer.
I'll play with mine 2mrw to see what I can come up with.
Old Apr 7, 2012 | 11:08 AM
air's Avatar
air
3rd Gear
Default headlamp door problems
When I turn on the lights everything is fine but when i turn off the lights
both doors close and then the left one comes up halfway. I can crank it down manually. Is it the headlamp control nodule?
Old Apr 7, 2012 | 04:46 PM
ryrob's Avatar
ryrob
Nope. You need to check out the GM service bulletin, tsb 00-08-42-002 for the LH headlight shim fix.
Old Apr 7, 2012 | 07:58 PM
egrand333's Avatar
egrand333
Just for an update, I got a used headlight module but before putting it in I jiglgled the connecting wires around on the old one and tapped it a couple of times with a wrench and have not had the problem return (yet).
To Head light pop o[ issue.
