Replacement key for 2000 vette
Old Jan 15, 2011 | 06:54 PM
Claybrdr's Avatar
Claybrdr
2nd Gear
Default Replacement key for 2000 vette
Lost a key and understand their is something called VATS that I need to understand to get a new key. Sorry for the dumb question but how do I find out what number is imbedded in my key?
Old Jan 15, 2011 | 07:01 PM
lucky131969's Avatar
lucky131969
You have to measure the resistance of the pellet. Based on that value, you can order the correct key:
Old Jan 15, 2011 | 07:16 PM
imavettegirl's Avatar
imavettegirl
isn't the pellet on the key?
Old Jan 15, 2011 | 07:28 PM
lucky131969
Yep.
Old Jan 15, 2011 | 07:35 PM
k24556's Avatar
k24556
I went to a local locksmith. In the shop they had GM VATS keys and could measure the pellet and cut the key. The head of the key does not have the same shape as the original, but for $16.95, I just needed a spare. It works fine.
Old Jan 15, 2011 | 08:05 PM
imavettegirl
how did they measure the pellet if it is on the lost key?
Old Jan 15, 2011 | 08:09 PM
lucky131969
Most people have two keys for their vehicle. The OP did not state he lost his ONLY key. I'm not a mind reader, just posting one possible solution.
Old Jan 15, 2011 | 08:43 PM
imavettegirl
maybe that is it.
Old Jan 16, 2011 | 01:07 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Lost a key
Old Jan 16, 2011 | 04:36 AM
LoneStarFRC's Avatar
LoneStarFRC
Any GM dealer. Bring car title (it has VIN) and ID to prove ownership. They can then cut the correct key for you.
Bring ankle handles too.
Old Jan 16, 2011 | 06:26 AM
Claybrdr's Avatar
Claybrdr
2nd Gear
Thanks for the responses. Yes, I still have one key or I would really be SOL. I had no idea how to measure the resistance and am glad a locksmith can do it.
Old Jan 16, 2011 | 07:02 AM
k24556's Avatar
k24556
You should be able to find a locksmith in Roanoke. If not, I got mine measured and cut at Hawkins Lock Shop on Fort Ave. in Lynchburg. As I said in a prev post, the head of the key is not the same shape, but the key DOES work.
Old Jan 16, 2011 | 01:33 PM
00Corvette's Avatar
00Corvette
I'm pretty sure you just set your meter to OHMs and then touch one lead to each side of the pellet..
Old Jan 16, 2011 | 04:15 PM
LoneStarFRC
Once the number is known, you can buy an identical GM key (same size, same design with bowtie emblem, etc) on the auction site for cheap ($14.99) and take it to any locksmith to cut the teeth to match your other key. That's what I did when I wanted to replace one of my old, worn keys.
Old Jan 17, 2011 | 09:55 AM
memmer's Avatar
memmer
I took my #1 key to the locksmith and he cut me a new key for $25.00 and gave me a #2 used fob for $20.00.I'm very happy I didn't have to go to the stealership for much more $$$$
Old Jul 7, 2011 | 01:33 PM
BrianZ4's Avatar
BrianZ4
2nd Gear
I have tried two different Multimeters and both read 743 which is not on your list. This is for a 2002 coupe 6 speed.
Old Jul 7, 2011 | 01:48 PM
65GGvert's Avatar
65GGvert
What range do you have the DVM on? If you have it on the K range, you need a #13 vats (7,430 ohms). If you are measuring 743 ohms, your vats key is not reading right or your DVM's are off.
Old Jul 7, 2011 | 05:12 PM
BrianZ4's Avatar
BrianZ4
2nd Gear
Thanks, I will check it out.
To Replacement key for 2000 vette
