wheel Spacers
Old Jan 17, 2011 | 12:14 PM
BigRobDsp's Avatar
BigRobDsp
Default wheel Spacers
I was looking for a 1/4 inch spacer (preferably local since I hate waiting for things) and I found a price range of $10 to $150. They all seem to be a 1/4 thick ring of Aluminium with holes stamped in them. Anyone know why there would be that much difference in pricing for a non-mechanical item like a spacer? also any advice on where to pick on up in East Dallas?
Old Jan 18, 2011 | 11:13 AM
BigRobDsp's Avatar
BigRobDsp
So no one even has an opinion on this?
Old Jan 18, 2011 | 12:09 PM
GeorgeZNJ's Avatar
GeorgeZNJ
St. Jude Donor '08-'09
I can't help you on the pick up, but I run a 1/4" spacer with my ccw's and 315/30/18's on the rear. There's nothing special about the metal, probably just a marketing gimic like the guy on here touting titanium lug nuts as a safety mod. As long as the bolt pattern is correct, no sense in paying a corvette tax.
Old Jan 18, 2011 | 12:28 PM
steponc's Avatar
steponc
St. Jude Donor '14
Default Spacers
The material used is the main reason for price differences. Some are cast aluminum and are a universal fit(low end), others are billet aluminum that is cnc'd to size (can include hub centric collar and anodizing).
Is the less expensive product less reliable? I think the vehicle use would have to be part of the decision.
I would try a good tire shop or custom wheel shops.
Old Jan 18, 2011 | 12:33 PM
BigRobDsp's Avatar
BigRobDsp
I ended up talking with a guy who made both the cast aluminum universal ones and CNC machined billet ones. He talked me into the CNC machined ones. He wasnt sure how any of them could be $150 as his are machined direct to the vehicle (hub centric) and had a tolerance of like a billionth of an inch or somthing. He also advised that the cast universal ones are typicly not as flat as the CNC ones. in any case they were only $25ea for him to CNC them.
Old Jan 18, 2011 | 12:47 PM
dgoetz's Avatar
dgoetz
the hub centric collar ones are more expensive and i am not sure they are worth it. But I would difinetly get Extended lug nuts so that you don't loose any thread securing your wheel to your hub.
Old Jan 19, 2011 | 12:05 AM
Joy of 6's Avatar
Joy of 6
I bought some spacers from Summit,inexpensive and fast delivery
Old Jan 19, 2011 | 07:44 AM
AU N EGL's Avatar
AU N EGL
Relaibilty may be more to do with the wheel studs and lug nuts used.
Do want to make sure you have most of the lug nut threaded on to the stud.
with a 1/4" spacer IMO you need longer studs too.
I run a 3/8" CCW spacer on longer ARP studs and Open ended hardened lug nuts
To wheel Spacers
