Try this: When you have the NO START issue, turn and hold the key to START and while your holding it in start, pump the CLUTCH Peddle on and off the clutch safety switch. When you do that you will hear the Theft Deterrent Relay in the passengers foot well click. That proves all the components up to and including the relay coil is good.
Heres a picture of the relay:
Its the relay with FOUR wires. Yellow, Yellow/Black, Red and PURPLE
Ok Bill this morning it happened again. I pumped the clutch while holding the key clockwise. The relay clicked. So thats good. I was not able to test with my voltmeter as I was late for work. But, atleast now I know all the components up to and including the relay coil is good.
Next time it happens I will test...
Just because the relay clicked, does not mean the relay contacts are good. I have changed two TDR's on other guys cars, that clicked when the clutch was depressed, but the contacts were broken inside, and the voltage was not making it to the solenoid. The meter is your friend.
lucky131969 - thanks for the pages out of the Service Manual. This is where the confusion comes in.
On page one, in paragraph 5, it says: "If the correct resistance value is sensed when the ignition switch is in the RUN position, the BCM will ground the theif deterrent relay control circuit and enable the fuel delivery."
But on page 2, under "Body Control Module", it says: "The BCM reads the key code from the ignition cylinder when the ignition is turned to the START position."
To me, the START position is when the key is turned to the position that cranks over the engine. So there seems to be some conflict in these statements.
My gut feeling is once the key is inserted and the ignition switch turned to the ON position without starting the engine, the Security light will go off if the key was read correctly, and the BCM/PCM will have then also been initialized and the starter should crank over if everything else is working properly.
If the Security light is on or flashing when the ignition switch is turned to just the ON position, then the key was not read correctly.
Thoughts?
I would not get caught up on the wording, as both statements are really true, they just forgot to include(on page 2) that it should be "RUN / Start" positions.
I don't think both statements necessarily mean the same thing, as the terminology means something specific. There are 4 positions on the ignition switch ... namely: OFF, ACC, ON and START.
There is no "RUN" position, but I guess they probably mean the "ON" position. There is a difference between the "ON" and "START" positions.
Ok partner, whatever works for you. Hopefully, you can make sense of it all.
From the Owner's Manual:
Security Light
This light comes on to
remind you to arm your
theft-deterrent system. If it
comes on and stays on when
your ignition is on, there
may be a problem with your
So, if I had to surmise, I'd say that when the ignition is turned to the ON position without cranking the engine, if the PASS Key system is working correctly, the "Security" light will go out. If the PASS Key system is faulty, then the yellow Security light will be on before you even try to crank the engine ... and cranking will result in a no-start.
Does not happen all the time. Car starts just fine when it does happen and after 2-3 mins of driving the security light comes on and stays on. Here lately it has happened every day.
The B2721 is the problem. It's for the pass key detection circuit. You can try using your spare key. If that does not resolve the issue, a new lock cylinder may be required.
The DTC write ups and the schematics use the ON & RUN terms equaly so, I dont think it matters much.
BC
I can buy that ON = RUN. But the discrepancy is that the manual says the BCM reads the key code when the key is in RUN and in START. I think it really reads the PASS-Key and grounds the thief deterrent relay control circuit and enables the fuel delivery before the key ever goes to the START position. Just a conflicting detail in the manual.
I think you should write GM, and explain the mental anguish this has caused you. You may be entitled to compensation.
I guess you're really not in to technical details like I am ... This is the "C5 Tech" forum, right? The manual is contradicting ... you obviously don't care.
Good lord.....I hope you get your period soon......
You're the one having the problem with me discussing this issue ... so who's really on their period? Did you write that section of the shop manual or something?
Well, NOT to steal anyone's thunder but I've been having some start issues and as of late, the codes are P1631 (H) (Theft Deterrent Enable Signal Not Correct), and B2721 (H) (Passkey Detection Circuit).
I have tried the spare key but to no avail but havn't tried the clutch pumping technique to see if the relay was clicking. I've noticed that when the car DOESN'T start, the "Security" light flashes continuously but if its going to start after I put the key in the ignition, the light comes on flashing and then goes out. So now I'm trying to decide if I should replace the ignition switch or the TDR. Any suggestions? Thanks in advance.
If the PASS-Key is not read correctly by the BCM, the Security light will come on and the BCM/PCM will not enable a start - ie, the TDR relay will not even get enabled for a start cycle.
Did you try cleaning both key pellet contacts? With age, the metal gets a coating on it ... could be both keys are coated. Take a soft pencil eraser and burnish the pellet's metal contacts then wipe with some rubbing alcohol. If that doesn't work, then I'd say the ignition switch is defective and can't read the key's resistor.
Also, your codes are History (H), so clear them and see what happens after cleaning the key pellet.
