Got a strange brake warning indication
Old Jan 29, 2011 | 08:50 AM
VetteDrmr's Avatar
VetteDrmr
Default Got a strange brake warning indication
This winter I've started seeing my brake system warning light pop up on the IPC, usually on accelaration, both in a straight line and in a turn (e.g. turning onto a highway).
One time was exceptionally strange. Turning off of a gravel driveway, the warning light came on, then, while accelerating in a straight line, the Active Handling system went berserk, applying brakes on both the left and right sides, then the DIC gave a "Active Handling" error message. I cycled power on the car, and never had another problem.
Here's the crazy part: no error codes!. No PCM or TCS messages, none! There were codes in the other systems, but I cleared all those out, and have experienced the Brake warning light momentarily coming on, and absolutely zero codes through the DIC.
Any ideas?
TIA, and have a good one,
Mike
Old Jan 29, 2011 | 12:19 PM
lucky131969's Avatar
lucky131969
Any ideas?
Mike
Have you checked the fluid level in the master? A number of things will turn the sight on. Low fluid, bad level sensor, wiring issue, or e-brake.
Old Jan 29, 2011 | 12:45 PM
VetteDrmr's Avatar
VetteDrmr
Sorry, I knew I didn't give enough info.
Fluid level is good. Don't know about the sensor, how could I check that without draining the MC? Checked the e-brake, that's working correctly.
Thanks for the ideas, keep 'em coming!
Have a good one,
Mike
Old Jan 29, 2011 | 01:17 PM
lucky131969
http://forums.corvetteforum.com/c5-t...ake-lignt.html
Old Jan 29, 2011 | 02:05 PM
VetteDrmr's Avatar
VetteDrmr
The brake warning light only comes on intermittently, and only for a few seconds. The sensor is definitely not in a hard failure mode.
Old Jan 29, 2011 | 02:15 PM
lucky131969
Ok, there just isn't too much to look at here. You can disconnect the sensor, and drive the car. If the light does not come back on, then the switch is flaky. If it does, then you have an issue with the e-brake, or wiring to the level switch.
Old Jan 29, 2011 | 03:34 PM
VetteDrmr's Avatar
VetteDrmr
Fair enough, I'll give that a shot. Sometimes the simple stuff is too simple!
Have a good one,
Mike
Old Jan 29, 2011 | 04:17 PM
jcgunn's Avatar
jcgunn
How OLD is the brake fluid? I had the brake system flushed on my 03 last year. As it turned out, 8 year old brake fluid was pretty much trashed.
Old Jan 29, 2011 | 04:42 PM
daleweible's Avatar
daleweible
I have experienced the same thing since last spring with it increasing ie I dont have to accelerate as had to come on, figured the sending unit, good fluid level, its a winter project I have not yet gotten to. I have never had it come on in braking only acceleration. I can't do any road test for a couple more months to much snow.
Old Jan 29, 2011 | 04:59 PM
AU N EGL's Avatar
AU N EGL
How old are your calipers? maybe time for new brake calipers.
Old Jan 29, 2011 | 05:41 PM
daleweible's Avatar
daleweible
I have an 01 Vert 6m. Though the calipers are original what would they have to do with a brake light comming on during acceleration?
Old Jan 29, 2011 | 05:53 PM
VetteDrmr's Avatar
VetteDrmr
I track the car regularly, I flush or bleed the brake fluid at least annually.
Also, I don't understand how even spread calipers could cause the brake warning indicator to come on.
Thanks again for all the suggestions, and have a good one,
Mike
To Got a strange brake warning indication
