Question about A/C clutch
Compressor Clutch Plate and Hub Assembly Removal V7 - Direct Mount
Tools Required
J 33013-B Hub and Drive Plate Remover/Installer
J 33027-A Clutch Hub Holding Tool
J 41790 A/C Compressor Holding Fixture
Remove the A/C compressor from the vehicle.
Clamp the A/C compressor holding fixture, J 41790 in a vise and attach the A/C compressor to the J 41790 .
Hold the clutch hub and drive plate assembly (2) in place using the J 33027-A .
Remove the A/C compressor shaft nut with a 13 mm socket (1).
Thread the J 33013-B into the hub.
Remove the hub and drive plate assembly (1) by turning the center screw into the body of the J 33013-B and against the A/C compressor shaft.
Remove the shaft key and retain for reassembly.
