Basic Exhaust question
Old Feb 1, 2011 | 04:23 PM
fenixtxrbf's Avatar
fenixtxrbf
Default Basic Exhaust question
I have a 2000 coupe, I added B&B bullets axle backs and corsa x-pipe (after the stock H pipe weld snapped). If i was looking to upgrade the rest of the exhaust, headers and cats, is there another piece I'm missing?
Does it go
Header -> Cats -> x-pipe -> axle back ?
I guess im confused with the terms long tube and midpipe. Do the long tube headers go directly to the cats?
Also the 2000's have a different cat sensor setup or something right?
I'm pretty much just trying to keep my eyes open in the used parts section for something that i might need.
Thanks Nick
Old Feb 1, 2011 | 04:51 PM
TNRAT's Avatar
TNRAT
You have it right...some refer to the cat section as mids....
Old Feb 1, 2011 | 04:54 PM
m6 c5's Avatar
m6 c5
You basically have it down. Most long tube headers come with an x-pipe which either is catted or non catted. If you do not get an x-pipe with the headers you are going to need to do a little bit of fab work. Oh and the cat back will bolt up to the x-pipe just like it does the h-pipe.
Old Feb 1, 2011 | 05:00 PM
fenixtxrbf's Avatar
fenixtxrbf
since i have the xpipe done what should i look for. Long tubes with cats and no xpipe?
Old Feb 1, 2011 | 05:04 PM
m6 c5's Avatar
m6 c5
The cats go behind the collectors on the long tubes, you most likely have just replaced the section behind the factory cats which means you will probably want to get headers with a catted x-pipe.
Old Feb 1, 2011 | 06:03 PM
TNRAT's Avatar
TNRAT
Depends on the header you buy....Billy Boat comes header, cat section, x-pipe, axle back............LGs have cat section & X pipe as one piece..
Old Feb 1, 2011 | 09:05 PM
lionelhutz's Avatar
lionelhutz
LG's have separate pipes where the cats go so they can sell catted or catless systems.
You can either get a system that replaces the X-pipe or just get the headers and make up the pipes/cats to connect the headers to your x-pipe.
Peter
Old Feb 1, 2011 | 09:41 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Stainless Works System:
Old Feb 2, 2011 | 02:00 AM
manley845's Avatar
manley845
Do a before and after on the dyno and make sure it was worth it. would love to see the gains from just a long tube header install.
To Basic Exhaust question
