LSX 376 GM crate motor coil pack ?
Old Feb 6, 2011 | 12:13 AM
GREG O.'s Avatar
GREG O.
Default LSX 376 GM crate motor coil pack ?
If i put a GM crate motor to replace an ls2, it states u have to design new coil pack brackets... has anyone ever done that ?? thanks
Old Feb 6, 2011 | 03:13 AM
zeevette's Avatar
zeevette
They must have different valve covers for that motor. If you used stock covers, then you could use stock coil brackets.
Old Feb 6, 2011 | 08:23 AM
99blancoss's Avatar
099blancoss
Former Vendor
St. Jude Donor '10-'11-'12
We have a relocation kit for coils, the lsx376 comes with GM cast covers on it. You can put regular valve covers on it with the coil pack provisions... or use one of my relocation brackets and I make custom sets of wires to go with.
Old Feb 6, 2011 | 09:02 AM
GREG O.'s Avatar
GREG O.
Default Valve cover fit
Hi Chris,You can put regular valve covers on it with the coil pack provisions.....do u mean like zeevette stated...i can use my stock LS2 valve covers and stock coils and brackets and it will bolt up just finethanks GREG O.
Old Feb 6, 2011 | 09:16 AM
99blancoss's Avatar
099blancoss
Former Vendor
Yes sir !
Old Feb 7, 2011 | 01:50 PM
GREG O.'s Avatar
GREG O.
Yes sir !
"cool"
Old Feb 14, 2011 | 09:17 PM
ekimsinnigcm's Avatar
ekimsinnigcm
St. Jude Donor '11
pics of brackets?
Old Feb 15, 2011 | 02:44 PM
99blancoss's Avatar
099blancoss
Former Vendor
this is the billet setup
Old Feb 17, 2011 | 07:35 PM
ekimsinnigcm
St. Jude Donor '11
how much and will they work with the lsx376 covers?
Old Feb 18, 2011 | 02:36 AM
99blancoss's Avatar
099blancoss
Former Vendor
No you need to buy the whole setup. They could work with the cast covers I suppose if you can mount them somehow. Not sure how good you can weld cast aluminum and even then I dont know what those things are cast of either...
Old Feb 18, 2011 | 07:59 AM
AU N EGL's Avatar
AU N EGL
Good Looking Cover Chris
Old Feb 18, 2011 | 01:20 PM
99blancoss's Avatar
099blancoss
Former Vendor
Thank you
They are unfortunately not cheap. The Billet set up is $770 and the fabbed setup $660 complete. I make wires for them at $60 for the set. They are between truck wire and car wire in length
Old Feb 18, 2011 | 01:36 PM
zeevette's Avatar
zeevette
Thank you
So the complete setup, with wires, and coil brackets/engraved covers is $830? That's alot, but I've seen worse deals. Sure are pretty.
To LSX 376 GM crate motor coil pack ?
