fog light bkt
Old Feb 10, 2011 | 02:09 PM
redrocketride's Avatar
redrocketride
Default fog light bkt
does anyone have a layout print of the left and right fog light brackets?
got the lights and need to make the bkts.found a pic of a bkt but i need dims to lay it of of 16 GA sheet metal.
any help many thanks.
Old Feb 10, 2011 | 02:12 PM
lucky131969's Avatar
lucky131969
I guess you are not using factory lights.....the geometry is fairly complex.
Old Feb 10, 2011 | 02:52 PM
redrocketride
i got a full machine shop to use,shears, breaks, punches, we got most every thing here.
lunch time project.
whats the distance from the light mount screw to the center of the oblong hole.
thanks
Old Feb 10, 2011 | 03:10 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
lunch time project.
thanks
Man,,, If you can make those brackets, you will make a fortune. You cant just purchase just the bracket as I sure that your aware of. I was VERY LUCKY and found a set at Carslile for $15.
I will tell ya what I can do. I will templet them up with some templet paper and send you the templet. You can easly make a set that way. Let me find the brackets and PM me your mailing address.
Bill
To fog light bkt
