ls6 or bbk ssi?
Old Feb 11, 2011 | 03:48 AM
mobus's Avatar
mobus
Default ls6 or bbk ssi?
I've read alot on both manifolds but would like to know which one everyone thinks will give the best hp gains
Old Feb 11, 2011 | 07:10 AM
AU N EGL's Avatar
AU N EGL
LS6 especially when the engine bay gets HOT
Old Feb 11, 2011 | 10:32 AM
TheWildcat's Avatar
TheWildcat
HP would be a toss... sbc have used alu intakes for years and I think mine looks awesome...John
Old Feb 11, 2011 | 11:02 AM
n8dogg's Avatar
n8dogg
Your best gains are probably going to depend on your tune. I know with my LS6 with just a K&N intake and mufflers, I'm nearing 90% injector DC with +/- 0.2% LTFT's. A bigger manifold might make me go static, so consider injectors? Maybe some guys with manifold experience can chime in.
Old Feb 11, 2011 | 11:27 AM
~Josh's Avatar
~Josh
Banned Scam/Spammer
The Weiand/Lingenfelter looks a little more like the stock intake and the internals are a little better than an LS6. I picked up some power on my last car when I switched from LS6 to the Weiand with no porting. No I don't have the slip anymore as that was back in 2004.
Plus, they polish up nicely.
Old Feb 11, 2011 | 01:13 PM
VCUFAN's Avatar
VCUFAN
They definitely look nice.
Old Feb 11, 2011 | 03:27 PM
mobus's Avatar
mobus
i agree that deffinitly looks nice. what size tb would be needed for use on the lingenfelter manifold?
Old Feb 11, 2011 | 03:38 PM
~Josh's Avatar
~Josh
Banned Scam/Spammer
You can bolt up an 80mm right out of the box (like a BBK tb) or it can be opened up and tapped to accept a 90.
The base plate underneath is removable to let you internally port it, along with portmatching the runners.
Old Feb 11, 2011 | 06:14 PM
zeevette's Avatar
zeevette
Be patient, and a used FAST 90 will come along. This manifold beats all the others for performance gains. Not very pretty, though.
Old Feb 11, 2011 | 06:24 PM
-98-z28-darkness-'s Avatar
-98-z28-darkness-
i went from ls1 to bbk 85mm with a 85mm throttle body. got it tuned and he said from all the tunes he has done he has noticed that bbk is slightly better then ls6 probably the bigger opening.
To ls6 or bbk ssi?
