check engine code Ive never had before(P0833)
Old Feb 11, 2011 | 06:31 PM
Vettedriver986's Avatar
Vettedriver986
Default check engine code Ive never had before(P0833)
So this code keeps coming back after every time I reset it....
I installed a adjustable clutch master cylinder and have the pedal adjusted pretty low.
Could that impact it?
Old Feb 11, 2011 | 06:53 PM
heavymetals's Avatar
heavymetals
The pedal adjustment is probably not activating the cruise control switch, ergo the code.
http://www.aboutautomobile.com/DTC/P0833
Old Feb 11, 2011 | 07:04 PM
Vettedriver986
so what should I do to correct it?
Old Feb 11, 2011 | 07:36 PM
heavymetals
Either raise the pedal or move the switch activation point.
You might have to do some searching on how to.
There is a spring that is supposed to return it (the pedal) to the top.
Old Feb 11, 2011 | 09:19 PM
Jnape's Avatar
Jnape
Are you limiting the pedals return point? When you say a low pedal do you mean low engagement point? as this is not an issue.
Old Feb 11, 2011 | 11:36 PM
Vettedriver986
with the tick master clutch cyl you remove the spring, and I have it adjusted so that the pedals return point doesnt bring it all the way up to that sensor... I had to adjust it this way because before, it was over extending my clutch pressure plate fingers and grenaded my last clutch. Not interested in doing that again
Old Feb 13, 2011 | 01:02 AM
Vettedriver986
I adjusted the switch so that It would meet the pedal..... no more code.
To check engine code Ive never had before(P0833)
