window inoperable, passenger side
My '03 Z06 has the usual power window issue. I went out to the shop this afternoon & did some troubleshooting. It has the typical symtoms: Didn't operate at first, can hear the clicking coming from inside the door & the interior lights dim slightly when trying to raise or lower the window, hammered on the door panel on several occasions with no success, then one day it started to work. Cycled the window every time I was in the car, then it quit working again. Removed the door panel & speaker assembly today & disconnected the harness on the regulator motor. The connector pins were clean & looked good. Used a multimeter to check voltage at the connector, there's battery voltage when activating the switch in either direction indicating the electrical system is good. I then removed the 4 screws holding the motor housing onto the gear box & removed it. All looked good inside (what little I could see) except the motor bearing looked dry. The armature turned freely in both directions by hand & the window mechanism looked good (cables snug, pulleys intact, etc). Lubed the motor bearing & reassembled the motor, used contact cleaner on the connections, applied dielectric grease & reconnected the harnesses. Now it works again (for now). Here's my thoughts: This appears to be a motor issue, my best guess is a poor connection between the brushes & the commutator caused by corrosion. It makes sense that hitting the door panel while holding the window switch might vibrate the armature enough to make a connection, or rotating the armature by hand might help make the connection also. Now I haven't had the motor completely apart so I don't know how much spring pressure there is on the brushes, but I was thinking more spring pressure may be needed. I fully expect it to fail again as I really didn't make much of a change. Any thoughts?
Good LuckLast edited by David426; Feb 15, 2011 at 05:32 AM.
The motor freezes up due to friction caused by lack of lubrication. If you can hear the relay in the DCM close it's most likely motor friction, not electrical. The brushes have plenty of spring force and the plastic spring guides on the cables will fail long before the brushes wear down enough to pop out of their guides. (Yes, I've taken them apart and examined every centimeter of the regulator.) Just continue to exercise the motor every now and then as you do now and when it stops working do exactly what you did this time.
...but when the window starts to jerk on the way down the spring guides have failed and it's time for a new regulator. Based on the suggestion of another forum member, I've started raising my windows to 99.9% of full upward travel to take some stress off the spring guide. Based on the failures I've seen I think it might make a difference in how long the regulators last. Eventually one of the aftermarket guys will sell a rebuild kit. But for now OEM replacement regulators are still available for less than $200.
