Looking for Crate Engine. Something Fun.
Old Feb 16, 2011 | 09:34 AM
gra03vette04's Avatar
gra03vette04
Default Looking for Crate Engine. Something Fun.
Well bad news here. To make a story short. My car had to be left somewhere in an ice storm. When I went back to pick it up the freeze caps came off. I had only hoped that was it. After getting it towed home and looking at it a week later their is oil on the floor. I am going to get it checked but more then likely the block is cracked.
Therefore I am looking for a crate engine. I dont want to spend a rediculous amount. But I do not just want the traditional stock LS1. Looking for something that is under 450-500 hp.
I am not trying to spend over 6k on this.
Any suggestions.
My car is a 2003 C5 Corvette.
Old Feb 16, 2011 | 09:45 AM
lucky131969's Avatar
lucky131969
Any suggestions.
Yikes. What were you using for coolant?
Old Feb 16, 2011 | 09:46 AM
SoDiezl350's Avatar
SoDiezl350
I would personally buy used.
Cheapest new LS6 crate motor I found was for around 6k: http://cgi.ebay.com/ebaymotors/New-C...item3ef45c7053
LS2s however are much cheaper and I found a rebuilt one for 3200:
http://cgi.ebay.com/ebaymotors/REFRE...item3a62214279
The LS6 is more desireable but for its not worth the extra money. The LS2 isn't a direct swap though so read this and see if it's too much work: http://www.ls1tech.com/forums/genera...de-please.html
Old Feb 16, 2011 | 01:24 PM
zeevette's Avatar
zeevette
I'd go with a custom motor built by one of our vendors. If you really want GM, look at the hot cam LS3. You might as well spend a little more now, to get a lot more, long run.
Old Feb 16, 2011 | 03:36 PM
kh400's Avatar
kh400
Check with Scroggins Dickey Chevrolet in Texas. I bought a new LS-6 long block from them for $3200, Maybe they still have some? Good luck.
Old Feb 16, 2011 | 03:47 PM
CHJ In Virginia's Avatar
CHJ In Virginia
Go with a LS6 long block. 405 HP, lots of torque and all of your accessories, wiring, etc. will work. They are available for + or - $3500 and have a warranty.
Old Feb 16, 2011 | 03:57 PM
gra03vette04
There are so many choices to choose from. I do not remember which coolant came in but I will make sure that it has really good coolant this next time. I live in Dallas and it rarely ever gets as cold as it got. It was a record low in like over 10 years.
Old Feb 16, 2011 | 04:03 PM
AU N EGL's Avatar
AU N EGL
Old Feb 16, 2011 | 04:17 PM
Toque's Avatar
Toque
From: Wylie TX --> Less is More, except under the hood !
Ouch.... sorry about that. I am in Dallas too. It sure was cold the last few weeks... A few mornings it was under 0 F !
I hope you get back on the road soon !
I recently changed my coolant to Prestone Dexcool Premix Extended life. Its good down to -34F.
Toque
Old Feb 16, 2011 | 04:24 PM
lucky131969
Sounds like it was way to diluted. Did the heater core and radiator survive?
Old Feb 17, 2011 | 11:34 AM
rboineau's Avatar
rboineau
As I understand it, the LS3--base motor for the C6--is available in a crate for reasonable $. It goes into a C5 with just a couple of minor tweaks needed and gives you 430 horses plus that extra response from its slightly larger displacement. I also hear that if you want to make a simple cam swap before putting the LS3 in you can up that figure 30 to 50 horsepower('tho that would kill any warranty you might get with the crate engine).
To Looking for Crate Engine. Something Fun.
