Shock Install
Old Feb 17, 2011 | 04:39 PM
Dolfan's Avatar
Dolfan
Default Shock Install
I've done the shock install once before on my Z06 using the "Zip Tie" method and while it worked it was a bit tough. If you don't get good enough ties on the shock they stretch and pull apart.
What other methods are there? It doesn't seem right that you would have to disconnect the A-arms, I don't want to go through that.
I've looked for "shock wrenches" but that just shows adjustment tools or compression tools for a strut type install when you have the spring to deal with.
Any other ideas?
Old Feb 17, 2011 | 05:15 PM
Cardinal Flyer's Avatar
Cardinal Flyer
I just put shocks in; zip tie method.
Picked up some EXCELLENT zip ties at Ace Hardware---about a dozen in a package, each about 18" long and unbreakable!
Wish I had found a better way, but beats taking the suspension all apart!
Old Feb 17, 2011 | 05:33 PM
Dolfan's Avatar
Dolfan
Yeah, just can't believe there isn't a shock compression wrench/tool for this????? OK, I guess I go the same route!
Old Feb 17, 2011 | 09:17 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Just get some mild steel wire and make a loop on one end, compress the shock, wrap the wire around the compessed shaft with one loop and once its inplace, cut the steel wire with a pair of cutters. It will expand in place and jsut remove the wire.
You can even use a metal coat hanger but, it a little thick!
BC
Old Feb 17, 2011 | 10:31 PM
bassfisher's Avatar
bassfisher
Use safety wire. Or just buy some good quality zip ties.
Old Feb 18, 2011 | 12:14 AM
VCUFAN's Avatar
VCUFAN
Yep, zip ties do suck. Would have been nice to have some sort of compression tool.
Old Feb 18, 2011 | 02:09 AM
Last C5's Avatar
Last C5
AH, but there is . . . .
and it works equally as well on C5, C6, and Bilstein shocks. Get out in your shop and whip one up.
Old Feb 18, 2011 | 07:32 AM
runner140*'s Avatar
runner140*
The large ones, the ones used for handcuffs, work great.
Old Feb 18, 2011 | 09:27 AM
Dolfan's Avatar
Dolfan
OK, that is what I'm talking about!!!! I really think something like that would make life easier. I was thinking to do the same thing.
Old Feb 18, 2011 | 10:01 PM
lionelhutz's Avatar
lionelhutz
Use some fairly fine wire like was already suggested. It doesn't stretch so it'll hold them compressed.
Peter
Old Feb 18, 2011 | 10:54 PM
Paul 75 L82's Avatar
Paul 75 L82
Looks easy to make the tool. Think I'll make one when I do my shocks.
Old Feb 20, 2011 | 11:03 PM
m-nelson's Avatar
m-nelson
What other methods are there? Any other ideas?
I've done it with nothing but PVC tape. Compress the shock & hold it that way. Run a few long strips of tape the length of the shock to hold the 2 halfs together. Then wrap around the the shock at the top & bottom to hold the long strips in place.
If you don't catch the tape on anthing, it hold well enough to get the shock in place.
Old Feb 21, 2011 | 08:01 AM
dmarkshark's Avatar
dmarkshark
I just did mine this weekend. I used a wood clamp to compress the shocks, and an old guitar string (the thickest one) with a loop at the end. Suprisingly the string lasted for all four shocks. I also used a jack under the A arm to help in getting the bolts out. Once I got the guitar string method figured out, it was a breeze, just kept on strumming.
Old Feb 23, 2011 | 11:51 AM
C5Longhorn's Avatar
C5Longhorn
I've used both zip ties and wire. Not too much of a problem with either.
Old Feb 23, 2011 | 12:06 PM
BitViper's Avatar
BitViper
And you know this just how.......hmmmm
Old Feb 23, 2011 | 07:37 PM
Dolfan's Avatar
Dolfan
Thanks all. I did it with zip ties, but had a few break and cause frustration. I still like that idea of a tool to clamp it down but I didn't have the spare time to slap that together first, just needed it done and it is!
To Shock Install
