Ring and Pinion
Old Feb 25, 2011 | 10:26 PM
corvettedaddy11's Avatar
corvettedaddy11
Default Ring and Pinion
Can you replace the ring and pinion or do you have to change the whole center section?
Old Feb 25, 2011 | 11:11 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
What are your goals???
What rear-end ratio do you have and what do you want to change it to???
If you have a 273, your very limited.
You have to have a SPECIAL Kent Moore Set up tool to set the rear-end clearances. Its not going to happen without that tool
Here are TWO excellent post on rear-end up-grade knowledge and a look at whats inside the rear:
- C5, Its Go Time, Output Shaft Install - Left and Right : http://forums.corvetteforum.com/c5-t...post1573404441
- C5 RAGTOPWS6, Differential UP-Grade; http://forums.corvetteforum.com/c5-g...-z06-guts.html
Old Feb 26, 2011 | 01:05 AM
corvettedaddy11
Thanks Bill......!
To Ring and Pinion
