If you're using the Amsoil series 2000 oil, transmission fluid, or gear lube (or other products) I would like to hear about any benefits or problems you've experienced. I getting ready to install the above three products and was curious how many others are using Amsoil products. Thanks.
I am using them front to back with no problems. Only difference is I used the 5W-30 rather then the Series 2000 which is 0W-30 oil. I wanted to stay with a weight that is recommended by GM. It is also a little less money. No problems here, and the tranny seems to shift a little smoother.
I use Amsoil Series 2000 0w30,75w90 Gear Lube & Universal Dexron III ATF :yesnod: :yesnod: :yesnod: Go with the FIRST & BEST!
You will not be :mad or :cry
You will be all :D :D :D
But Don't pay Retail :smash: :smash:
Have tried Amsoil and Redline in my 6 speed. Amsoil shifted a little bit better than factory fluid.
When I switched out my Amsoil fluid with Redline. Redline shifted much smoother than Amsoil. If you want much more smoother shifting, go with the Redline in your transmission.
