voltage drops after rev
Old Mar 4, 2011 | 07:55 AM
kj217's Avatar
kj217
Default voltage drops after rev
the voltage drops momentary while the rpm is going down after a rev on neutral,,
anyone heard about that before?
99 C5 MN6
Old Mar 4, 2011 | 08:19 AM
65GGvert's Avatar
65GGvert
Sounds like you're really struggling to find something wrong.
Old Mar 4, 2011 | 08:21 AM
rebelheart's Avatar
rebelheart
Indeed!
Old Mar 4, 2011 | 08:31 AM
kj217's Avatar
kj217
believe me,, this vette is all wrong,,
Old Mar 4, 2011 | 08:34 AM
lucky131969's Avatar
lucky131969
99 C5 MN6
How much of a voltage drop to you see? Does it drop with an RPM dip?
Old Mar 4, 2011 | 08:37 AM
kj217's Avatar
kj217
it drops to 10-11v,, no rpm dip,, voltage drops while the rpm is normally going down,,
Old Mar 4, 2011 | 02:35 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Where are you reading this so called VOLTAGE DROP reading??????
If it on the DIC/IPC Volt meter, YOU ARE NOT reading actual battery voltage. Your reading the voltage AFTER the IGNITION SWITCH>
READ the voltage directly on the battery terminals and see what its doing.
IF,, your seeing a voltage drop there, you either have:
1. POOR connection on the BATT wire on the back of the alternator.
2. POOR connection on the STARTER SOLENOID (The alternator charge wire connects there and them goes to the battery.)
3. POOR contact.connection on the battery terminals. Can you move the terminals by hand?? If so,,, thats a problem!!
BC
Old Mar 4, 2011 | 02:38 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
If all the above checks out good,,,
Numerous C5 owners are starting to see many defective ignition switch issues. Heres an entire post on that very topic. Check it out:
-C5 ignition Switch repair - http://forums.corvetteforum.com/c5-t...ch-repair.html
Old Mar 4, 2011 | 04:09 PM
kj217's Avatar
kj217
thanks Bill for the info,, i will check all the points and let you know,,
To voltage drops after rev
