Overheating Issues
Old Mar 5, 2011 | 11:33 PM
MarkCBlock's Avatar
MarkCBlock
Cruising
Default Overheating Issues
I have a 1998 C5 that is experiencing extreme overheating issues. I started by replacing radiator cap, then thermostat and housing, today the radiator (old radiator had small leak up on to by outlet). It still overheats. The hose attached to the thermostat never did get hot. There appears to be no leaks. Is the next route to replace the water pump? PLEASE HELP!!!!!!
Old Mar 5, 2011 | 11:43 PM
01'IndyVette's Avatar
01'IndyVette
Sounds to me like you have air in the system. If you search there is a way to "burp" the system.
Old Mar 6, 2011 | 08:35 AM
vsocks1's Avatar
vsocks1
Burp system first and them if you still have problems check the water pump!
Old Mar 6, 2011 | 08:36 AM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
I don't think you have a water pump issue. Yes, insure there is no trapped air by following the burp procedure already provided to you. Next, check to see if your fans are actually running. You can do this simply by turning on the hvac to recirc with a cold temperature selected. Make sure both fans are running. Lastly, check for debris blocking the condensor. You may need to wash it or blow it out.
Old Mar 6, 2011 | 09:25 PM
MarkCBlock's Avatar
MarkCBlock
Cruising
Default still overheating
I did the burp, it didn't work. There is no water leaking or the traditional sound of a water pump comming apart. The lower hose attached to the thermostat housing was still cold with the engine overheating. Any additional suggestions would be appreciated.
Old Mar 6, 2011 | 10:41 PM
dgrant3830's Avatar
dgrant3830
Hope you didn't mix coolants...it'll possibly turn to sludge.
Old Mar 7, 2011 | 12:13 AM
Chicago1's Avatar
Chicago1
Isnt 210 way to hot to just turn the motor off and take the cap off without it burning/exploding in your face?
Old Mar 7, 2011 | 07:49 AM
dgrant3830's Avatar
dgrant3830
Could be simply that the tstat has failed.
Old Mar 7, 2011 | 08:35 AM
MarkCBlock's Avatar
MarkCBlock
Cruising
Thermostat , radiator and radiator cap have been replaced. I am going to pull thermostat today and try running without thermostat to see if that works.
Old Mar 7, 2011 | 09:11 AM
helga203's Avatar
helga203
Try hitting the stat housing not to hard might break free diff sounds like stat stuck.my .02
Old Mar 7, 2011 | 09:34 AM
dgrant3830's Avatar
dgrant3830
Maybe you got a bad one or it was installed backwards if that's even possible? I have not seen the C-6 tstat yet, so I don't know.
Old Mar 7, 2011 | 09:44 AM
AU N EGL's Avatar
AU N EGL
take the radiator out. Have it boiled to get all the crap out of fines and out of the core, then replace
or just buy a new radiator.
Old Mar 7, 2011 | 01:36 PM
dougbfresh's Avatar
dougbfresh
What temp does it get to? Do the fans come on.
Old Mar 7, 2011 | 06:01 PM
billla's Avatar
billla
St. Jude Donor '14
<subscribed> I'm dealing with this too :/
Old Mar 7, 2011 | 09:16 PM
Dolfan's Avatar
Dolfan
Is it possible to "speed" the burping process by parking it on a hill nose up? I know this helps my C4 by changing the level of the cap and fill compared to the rest of the system.
Old Mar 7, 2011 | 09:19 PM
lucky131969's Avatar
lucky131969
I think you should try it, and report back. I'm curious how much time you can shave off of the exhausting 30 minute procedure.
Old Mar 7, 2011 | 09:33 PM
Dolfan's Avatar
Dolfan
Well from my perspective the process outlined by 8Vette7 which may be spot on has 16 steps according to his write-up. I was only thinking that changing the angles might simplify greatly the number of steps in the process, I know with my C4 it goes lke this
1 park it up hill, cap off
2 run to temp
3 fill to level, check level in radiator
4 replace cap
Just wondering if it could be simplified.
I'm leaving all the other things I wanted to say about the tone/comments of the previous post to myself. Just trying to be constructive!
To Overheating Issues
Old Mar 7, 2011 | 10:18 PM
lucky131969
2 run to temp
4 replace cap
I've heard this wives tale for years, and often wondered where it came from. When they first fill the coolant at the factory, they don't elevate the nose of the car. When they service the cooling system at the dealer...they don't elevate the nose of the car. Somehow, the only people that have to elevate the nose of a corvette, when filling the cooling system, are the corvette owners. Coincidence?
Old Mar 7, 2011 | 11:16 PM
lucky131969
Originally Posted by 8VETTE7
On that car the overflow tank was mounted very low and you filled the radiator rather than the overflow tank.
.....which was typical on virtually all cars previous to that(except for my C2)....for those of us old enough to remember.
Old Mar 8, 2011 | 07:09 AM
dougbfresh's Avatar
dougbfresh
This "Burping" procedure seems silly-I changed my coolant by draining and refilling and running with the tank open till it warmed up. As long as the overflow tank is above the radiator it should be simple. Many GM's I have owned or have now have a bleeder screw(s) for bleeding air out of the system (3.1, 3.4 and 3.8 liter engines)-the C5 didn't come with one-funny huh??
Many people think the temps the C5 runs it too hot when compared with other cars-it was designed to run hotter (many discussions on this)-if both fans come on and the temp still stays above 190-200 for long periods MAYBE there is an issue but I think the OP has some other issue but I don't recall him saying what temps it's running and if the fans are coming on at the correct temps.
