Headlight problem
Old Mar 6, 2011 | 03:03 PM
jazzvette's Avatar
jazzvette
Default Headlight problem
I have an 99 model and the lights(headlights) won't go off with the car on or off. I'm having to disconnect the battery. Need Help on ths issue. Tried to reset in DIC with sucess.
Old Mar 6, 2011 | 06:13 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
First, do you have the twighlight sentinel option in the DIC? If so, set the time delay to 0. Pull your codes and see if anything shows up in there. Do the headlamps go down but stay on or do they stay up and on? Do you hear the "ding" warning when you open the door with the headlamps on?
Old Mar 7, 2011 | 07:50 PM
jazzvette's Avatar
jazzvette
Default Headlights
Yes, the headlights stays up when the car is off and has the ding warning sound when you open the door.
Old Mar 7, 2011 | 08:09 PM
lucky131969's Avatar
lucky131969
Have you checked minifuse #6, in the passenger footwell?
Old Mar 7, 2011 | 08:10 PM
dgrant3830's Avatar
dgrant3830
In this case, if you mess with the headlamp switch at that time, does anything change? There's only two possibilities that I can consider at this moment would be the headlamp switch has a shorted contact or the headlamp relays are stuck on/closed.
Old Mar 7, 2011 | 08:11 PM
dgrant3830's Avatar
dgrant3830
To find out, you'll need to remove the knee bolster and gain access to the large connector from the headlamp switch and while the lamps are on, pull that connector apart and see if the lamps go out.
To Headlight problem
