used absfixer, code 15k miles later
Old Mar 10, 2011 | 04:34 AM
4SFED Z's Avatar
4SFED Z
Default used absfixer, code 15k miles later
So my car throws c1214 hc code last night. Its the same code I had 15k miles ago. Absfixer did the fix and things were fine until now. Wtf.I cranked up the car and came up. Before I pull it and send it back, any thoughts on a fix?anyone else had absfixer fix the module and threw the damn code again? Thanks
Old Mar 10, 2011 | 04:56 AM
trussme's Avatar
trussme
Default ITZ " Warranted"
send it back....here is his guarantee:
Call Brandon
877-648-7530 at ABS FIXER
or: www.absfixer.com
$150. plus UPS....warranted as long as you own it
Old Mar 10, 2011 | 05:31 AM
4SFED Z's Avatar
4SFED Z
Yea. Odd it just happened. I hate having to pull this thing.
Old Mar 10, 2011 | 09:41 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
100% satification! Send it back! Let us know how it turns out.
BC
Old Mar 11, 2011 | 02:42 AM
Bill Dearborn's Avatar
Bill Dearborn
You really need to check the BPMV motor winding to see if it has a partial short to ground. If the resistance measurement is less than infinite the BPMV has to be replaced as well as repairing/replacing the EBCM.
The check of the BPMV is part of the C1214 diagnostic procedure and shouldn't be ignored since the BPMV could be the reason the EBCM failed.
Bill
To used absfixer, code 15k miles later
