heater - a/c fan replacement
Old Mar 12, 2011 | 04:50 PM
racingchester's Avatar
racingchester
Default heater - a/c fan replacement
Need info on replacement of fan..Thanks Chuck
Old Mar 12, 2011 | 05:06 PM
lucky131969's Avatar
lucky131969
So you want info on the fan, or the blower motor?
Old Mar 12, 2011 | 06:40 PM
racingchester
Think its the blower motor as I am getting a growl.
Old Mar 12, 2011 | 06:44 PM
lucky131969
It's under the passenger side closout panel. Drop the panel, and you'll see it. The case is hot all the time, so disconnect the battery, if you don't want a mishap.
Old Mar 12, 2011 | 06:53 PM
racingchester
Thank you very much....
Old Mar 12, 2011 | 08:47 PM
ICUALL's Avatar
ICUALL
Default Did mine Friday
Just replaced mine yesterday, pretty straight forward as stated remove the access panel on the passenger side as well as fuse box cover (the carpeted panel not the box itself).
There are 3 bolts holding the blower motor and fan. They were 6 mm in my 2000.
The motor has a 2 prong plug on the back side on the driver side.
Simply have to lift the retainer and pull to remove it. I removed the plug before the bolts that way the motor and fan will come out. easier You may have to wiggle it a little to break the gasket loose.
When installing the new one do one bolt at a time until they "grab" then do the next, do NOT tighten them completely until all three have been started as you may need to rotate the position sightly to align
Old Mar 12, 2011 | 09:36 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Looks just like this!!
Remove the rubber cooling hose and squirt some oil in the lower bearing and see if that quiets it down Save a few bucks!
Old Mar 12, 2011 | 09:39 PM
ICUALL's Avatar
ICUALL
Great Pics Bill, the first one is the view I had laying on my back !!
Old Mar 12, 2011 | 10:05 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
THATS,,,, the same way I got that shot!!!
BC
Old Mar 12, 2011 | 11:36 PM
racingchester
Great pix. Might just replace. Getting to old to go back in a second time.........
To heater - a/c fan replacement
