My H/C/I setup
Old Mar 16, 2011 | 02:00 AM
DANZGLASS's Avatar
DANZGLASS
Default My H/C/I setup
I have been getting my parts together for my upcoming head cam intake swap. What do you guys think and what do you think it can do?
Charlie at rpm will be tunning.
2002 z06
Parts i have or are on the way
Tea tfs 220 as cast heads milled to 59cc with yella terra's
Spin ported fast 92 snout ported to 96mm with a nick williams 96mmTB
224-230 .581/.588 114 lsa XER
Powerbond 25% UD Pulley
Blackwing
Flp longtubes, high flows, x pipe
Svo 30's
all the other small odds and end parts gaskets bolts lifters.
Parts i have on already
Slp loudmouths
monster stg3 with light flywheel
Thank you for looking!
Old Mar 16, 2011 | 02:37 AM
jd86L98's Avatar
jd86L98
2002 z06
Blackwing
Svo 30's
Slp loudmouths
You might want to consider the cam Charlie put in my car I think he now calls it his ZZ530X cam. You will love it.
Old Mar 16, 2011 | 09:26 AM
AU N EGL's Avatar
AU N EGL
Good set of parts.
good choice and keep the cam.
Old Mar 16, 2011 | 09:48 AM
Jay_Rich's Avatar
Jay_Rich
only SVO 30s for peace of mind Id pick up a set of 36 or 42's they go for about the same price.
I had SVO 30s on my old LT1 at 315rwhp they were at like 75% duty cycle, although with LS fuel pressure im sure they are closer to 35#
Nice setup tho!
Jay
Old Mar 16, 2011 | 09:52 AM
DANZGLASS's Avatar
DANZGLASS
svo 30's are 36lbs on our cars. I'm pretty sure they are fine for mid to high 400's. I dont track my car much either. I looked up max on them and they hit 100% around closer to 500whp
Old Mar 16, 2011 | 10:16 AM
DANZGLASS's Avatar
DANZGLASS
the diff is the lobes on your cam are xfi but it really wont change much i have seen both cams make about the same power 415-430whp on stock ls6 heads and intake. I love the power curve of your car tough! I hope that mine has that nasty midrange torque like yours does!
Old Mar 16, 2011 | 12:25 PM
zeevette's Avatar
zeevette
Great looking component list. I guess about 460/430 RWHP/TQ after tuning.
Old Mar 16, 2011 | 02:23 PM
DANZGLASS's Avatar
DANZGLASS
I would love those numbers! I was only going to go with a cam at first but good deals keep showing up! Oh well LOL!
Old Mar 16, 2011 | 02:31 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
I have simular mods on my 02 ZO6. Here are some of the things that I used that made the job nicer:
ARP Head studs. FANTASTIC!
ARP Damper bolt.
MAP Relocation Kit
Side Pinned the damper to the crank
Melling High Volume pump
LS2 Timing chain
I used 42 lb/hr injectors and home ported my own FAST90 and 90 mm TB. I also used caddy racing lifters with my whiplash cam.
Bill
Old Mar 16, 2011 | 02:35 PM
DANZGLASS's Avatar
DANZGLASS
have the oil pump and timing chain already. I am having RPM do the install I think they pin the crank for all there setups. Do you know what your injector duty cycle is?
Old Mar 16, 2011 | 02:38 PM
DANZGLASS's Avatar
DANZGLASS
what kind of numbers did you get with the whiplash? Thats a big stick!
Old Mar 16, 2011 | 03:08 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
450 RWHP on the back street dyno at the Cruise In down in Bowling Green KY
Its not really that big of a cam. They make a LOT bigger now. Infact, with a goot tune it pretty streetable.
BC
Old Mar 16, 2011 | 03:36 PM
DANZGLASS's Avatar
DANZGLASS
Cool I have to worry about the smog tests down hear now so this cam is about as big as you can go. I still think i can get some good numbers with this setup. I have the small odds and ends parts to get still then its time to rock and roll.
Old Mar 16, 2011 | 06:18 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
I have to pass the CT Emissions test. Its about as strict as they come for a plug in test. I pass with flying colors. I don't even have any of my emissions flags tuned out..
Do you get a sniffer test or a OBDII plug in test???
Old Mar 16, 2011 | 07:12 PM
DANZGLASS's Avatar
DANZGLASS
Sniffer!
Old Mar 16, 2011 | 08:04 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Well, that rots
Old Mar 16, 2011 | 08:07 PM
DANZGLASS's Avatar
DANZGLASS
I have one more test next year then 2013 it goes OBDII.
To My H/C/I setup
Old Mar 17, 2011 | 02:54 AM
jd86L98's Avatar
jd86L98
You are correct and yes top end will be similar but like you mentioned look at my torque curve. I looked at both lobes with Charlie and I am very happy I went XFI. On the street the torque is great. If I ran a FAST setup I would probably hit 450rwhp with all the streetability of the lower duration cam.
Old Mar 17, 2011 | 11:25 AM
DANZGLASS's Avatar
DANZGLASS
Thank you for the info. I think the 59cc milled heads helps a lot on your torque too. Ryan L on here had your cam on stock 243 and it is a little soft until about 3500. But I have taken it into account on the lobes.
Old Mar 18, 2011 | 11:36 AM
DANZGLASS's Avatar
DANZGLASS
Forgot to mention the heads are worked on by tea and flow about the same as the tfs 215's
