Bearings, rings rods..?
Old Mar 22, 2011 | 03:18 PM
  #41
Leukic's Avatar
Leukic
Originally Posted by sabastian458
240 in oil temp seems high. I live in the Upstate of SC and my oil temp on the highway never exceeded 190 (unless I was running it hard that is) 2002 Z06. But I too am now performing an engine replacement.
on a normal day mine would never get above 205 unless I was running it hard. This temp was because of the spun bearing.
Old Mar 22, 2011 | 06:22 PM
  #42
zeevette's Avatar
zeevette
I don't mean to hijack, but I think my question is related. If you are going to replace only your shortblock, and want quality materials for a FI application, but you want to reuse your aftermarket heads, can you use a block with a larger bore? The stock bore pretty much limits you to a 383, and I've read this configuration isn't very long lived, due to the connecting rods geometry. Can heads be redone to work with larger bores, or is that even needed? My dream engine is a 4.125" X 4" 427. But I love my TF heads, and would like to keep them.
Old Mar 22, 2011 | 08:55 PM
  #43
sabastian458's Avatar
sabastian458
I believe ls1 heads can work on a ls2, but not larger bore
I am droping a LS2 long block into mine.
Old Mar 24, 2011 | 04:39 PM
  #44
All_Motor_C5LS6's Avatar
All_Motor_C5LS6
definitely the rod bearings
Old Mar 24, 2011 | 04:43 PM
  #45
All_Motor_C5LS6
Originally Posted by Leukic
Looks like a Stroked 383 with my same block or bigger.... pms replied just offer me some advice or guidance
thanks everyone.
Why not just overbore your current block and go with a 370ci. It'd last longer than a 383ci and make just as much power.
Old Mar 24, 2011 | 07:22 PM
  #46
Leukic's Avatar
Leukic
That is also an option. Got the motor ready to be pulled this weekend to see the real damage. But I will look into the 370 and research more about it
Old Mar 25, 2011 | 04:33 AM
  #47
ZZ06's Avatar
ZZ06
ive always wanted to know the answer to this as well. I know there will come a day where ima go bigger cubes....
