Coil overs - alignment
Old Mar 21, 2011 | 05:16 PM
mph1972's Avatar
mph1972
Cruise-In VIII Veteran
St. Jude Donor '07
Default Coil overs - alignment
Okay, installed the COIL OVERS, car sits about the STOCK HEIGHT. I am getting aligned right now, if I decide to lower it about 3/4 - 1" does this impact the alignment enough for me to need to get another alignment?
Remember I have COIL OVERS.
Micah
Old Mar 21, 2011 | 05:32 PM
00Corvette's Avatar
00Corvette
Why not lower it when you corner balance it, then go have it aligned?
Old Mar 21, 2011 | 06:34 PM
lionelhutz's Avatar
lionelhutz
Yes, lowering messes up the alignment. Doesn't matter if you have coil-overs or the stock springs.
Well, you could leave it if you don't care about wearing your tires out prematurely, especially the inner edges of the fronts.
Peter
Old Mar 21, 2011 | 09:36 PM
mph1972's Avatar
mph1972
St. Jude Donor '07
I am planning on getting another alignment once I get the car to California after shipping it.
The plan was only go to be lowering it a little bit, so about .5-1", but I can dig the 4 wheel drive look, maybe.
Old Mar 21, 2011 | 10:49 PM
Jnape's Avatar
Jnape
Alignments are cheap and tires are not (if you use quality tires). If you are shipping the car, why not wait if few miles are driven anyway?
Old Mar 22, 2011 | 03:51 AM
mph1972's Avatar
mph1972
St. Jude Donor '07
I measured everything and I am very close to where I want to be, so I am keeping things as they are. It is nice not to have to sweat every freakin' bump in the road.
Micah
Old Mar 22, 2011 | 10:07 AM
clif's Avatar
clif
St. Jude Donor '09-'10
Micah
This depends on what brand coilovers you have. I have the Pfadt coilovers, and Pfadt has special alignment instructions on their website.
Old Mar 22, 2011 | 11:03 AM
mph1972's Avatar
mph1972
St. Jude Donor '07
I have the LG GT2, and I am leaving everything alone. I aligned, the height is bareable and I am just going to enjoy the car.
Old Mar 22, 2011 | 11:52 AM
AU N EGL's Avatar
AU N EGL
most coil over will not allow much it any lowering.
Just set the right height properly, corner balance then align.
Old Mar 22, 2011 | 12:25 PM
00Corvette's Avatar
00Corvette
If you read up on username "solofast"...his posts will show that you will be WAY more satisfied with your cars handling if you don't slam it.(unless you use dropped spindles)
I believe you want the frame rails at the jacking puck points about 4.25-4.5 inches off the ground for close to the best handling.
Leave it up and enjoy the ride quality
Old Mar 22, 2011 | 03:02 PM
mph1972's Avatar
mph1972
St. Jude Donor '07
The car is sitting almost exactly the numbers you posted about, give or take a 1/8 of an inch. I am pleased with the setup and ride. I have been keeping up with SOLOFAST and his comments, he is pretty darn savy in this world. Gotta love the smart guys that have been around the block.
Micah
Old Mar 23, 2011 | 02:18 AM
00Corvette's Avatar
00Corvette
Micah,
Glad you got em' all installed and going. and enjoy. I'll have mine some day too.
Donnie
Old Mar 23, 2011 | 04:50 AM
mph1972's Avatar
mph1972
St. Jude Donor '07
I plan on building a nice detailed thread about the install to help others.
To Coil overs - alignment
