Replacing the BPMV.
Old Mar 27, 2011 | 04:24 PM
Sinking's Avatar
Sinking
Default Replacing the BPMV.
It looks like I will be replacing my BPMV. Obviously I will need to have my system bled using a Tech 2. Now, what I need to know is if I bleed the system conventionally and leave the harness off of the EBCM can I drive to the shop?
Using my hydraulics education and studying the internal diagrams I was able to find it looks like all off the solenoids are normally open and have a spring so without any computer or power to the coils there should be no way for them to open and let air in so the brakes should work like a straight no ABS setup.
Can anyone tell me otherwise?
Old Mar 28, 2011 | 07:01 AM
trussme's Avatar
trussme
Default no assists...
no abs, no active handling , no traction control...but you can drive it ....carefully!
Old Mar 28, 2011 | 08:28 AM
Sinking's Avatar
Sinking
I have been driving this car for about a year and have never had working abs/tc/ah.
So, cool...the brakes will still function like brakes while not letting any air in as long as I don't plug in the EBCM.
Old Mar 28, 2011 | 09:24 AM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
You will still have air in the lines even though you haven't got to the Tech 2 use yet in order to actuate the ebtcm and bpmv so driving to the dealer or service center will be a safety issue but it can be done. It would be best if you disabled them with the switch prior to moving it.
Old Mar 28, 2011 | 09:30 AM
Sinking's Avatar
Sinking
I wouldn't even plug the harness in to the EBCM...no power going to it.
Old Apr 7, 2011 | 07:54 PM
Sinking's Avatar
Sinking
Just reporting to anyone who searches this in the future... I bled the brakes and buttoned everything up keeping the harness for the EBCM unplugged. I drove to the shop without any issues to get the brakes bled with the Tech2.
Old Apr 8, 2011 | 12:26 AM
vetteracerx's Avatar
vetteracerx
Did the BPMV I sold you fix your prob??
Old Apr 8, 2011 | 06:00 AM
SMaster's Avatar
SMaster
Just curious, how much they charge to do that?
Thanks for sharing.
Old Apr 8, 2011 | 08:24 AM
Sinking's Avatar
Sinking
It fixed the blocked passaged that crept up out of nowhere but it looks like I still need to get an EBCM.
Thanks for sharing.
The dealer wanted $160. I found a very respected local shop who did it for $45. While I was there I also got a custom alignment done (what a difference!) and with the two services got out for $142.00.
Old Apr 8, 2011 | 08:29 AM
vetteracerx
That sucks! Whats it doin?
Old Apr 8, 2011 | 08:35 AM
Sinking's Avatar
Sinking
I am getting code 1267: RR outlet solenoid malfunction. I was hoping since my car was neglected and the brake fluid was disgusting that the solenoid was just sticky but it looks like it must be the coil in the EBCM or whatever it is that fails in that circuit.
Old Apr 8, 2011 | 04:51 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
The EBTCM does NOT know if the BPMV is working or not. The problem is in your EBTCM. If it were me, I would pull the EBTCM off and inspect that coil and make sure that the wire isnt broken
If you have the old EBTCM, install it and see if it changes the symptoms.
I hope Im understanding your issue and symptoms.
BC
Old Apr 8, 2011 | 04:57 PM
Sinking's Avatar
Sinking
BC
Bill,
I actually just got off the phone with someone at ABSfixer to see if they had any refurbs in stock and he was pretty much telling me the same as you. I had taken the EBTCM apart and didn't notice anything obvious. ABSfixer told me that the most common thing is the solder joint for the coil will crack so I am going to take your and his advice and open it back up to check those joints.
Old Apr 10, 2011 | 11:11 AM
Sinking's Avatar
Sinking
Here is a picture of the guts if anybody is interested. If you saw my other recent post you will have seen that I found a bad coil which must have been causing my 1267 code, RR outlet solenoid malfunction. I would not recommend taking this apart if you are inexperienced soldering or lack patience.
Old Apr 10, 2011 | 12:27 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Good Job! Were you able to repair the bad coil, reassemble and use???
BC
Old Apr 10, 2011 | 12:29 PM
Sinking's Avatar
Sinking
BC
I think I have a source for a new coil. I am hoping to have it sometime this week and back together by next weekend. For once I am feeling optimistic on this.
Old Apr 11, 2011 | 06:36 PM
Sinking's Avatar
Sinking
Hooray! I was able to find a coil for about $10.00. Hopefully get gets here before the weekend. I am looking forward to seeing if my skills can save me $700.00.
To Replacing the BPMV.
Old Apr 14, 2011 | 07:37 PM
Sinking's Avatar
Sinking
Welp... I got the new relay and coil in yesterday, reassembled it today, put it on the car, and drove it.
For the first time in the year I have had the car I had working AH/ABS/TC.
Old Apr 14, 2011 | 07:41 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
YOU DA MAN!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! :f lag: Great JOB!!
Glad it all worked out for you
Bill
Old Apr 14, 2011 | 07:45 PM
Sinking's Avatar
Sinking
Great JOB!!
Bill
Thanks. I did it all with my heavy Craftsman soldering gun since I can't find my smaller iron. I think I will finally pick up a nice station like I have been wanting. I play around with other electronics like tube amps as well so it would definitely get used. I also want to get one of those desoldering setups with the built in vacuum pump. I used one once and it was awesome.
