TPS learning
Old Mar 29, 2011 | 03:03 PM
Michael99Vette's Avatar
Michael99Vette
Default TPS learning
I am trying to re-learn my tire pressure sensors to the vehicle after a long dead battery. I got very good directions from the forum... but, after I learn the first sensor (L, Front), the IPC tells me to go to the (R, Front). No matter how many times I try, the R Front doesn't respond.
What now? or What do I do next?
Any help would be appreciated.
Thanks.
Mike
Old Mar 29, 2011 | 03:08 PM
GEMcLean's Avatar
GEMcLean
Sounds like a dead battery in the sensor.
Old Mar 29, 2011 | 03:17 PM
Michael99Vette
I assume there's no way to re-charge the battery in the sensor? I also assume that it was coincidence that this crapped out the same time my battery did, or did this dead battery cause the sensor to fail? I checked with a local Chevrolet Dealer... $184.00 plus tax for a new sensor. Wow and Ouch!
Old Mar 29, 2011 | 05:12 PM
MAC5's Avatar
MAC5
Driver your car around for couple of days then retry the TPS relearn procedure. Make sure you have a BIG magnet. If the sensor won't program, try placing the magnet inside the wheel barrel close to the valve stem. Check out TireRack for new sensors if needed. $63.00 each.
Old Mar 30, 2011 | 12:01 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
I know that there are GENEIC sensors now that replace the OEM sensors and they are a LOT less money! Walmat sevice centers even have them. See if Autozone or Advance can get them for you. You can replace the battery:
- Tire pressure sensor rebuild - http://forums.corvetteforum.com/c5-t...post1570376652 http://forums.corvetteforum.com/c5-t...-tutorial.html http://forums.corvetteforum.com/c5-t...post1575112894
If you have an ealy C5 (97-2000),, You can also completly convet the system to the late model TPS system:
-C5 Tire Pressure Monitor Sys Up-Grade 97-2000 to 2001 RFA System: http://forums.corvetteforum.com/c5-t...e-sensors.html , http://forums.corvetteforum.com/c5-t...aded-tpms.html
To TPS learning
