Reflashed PCM now wont start!!
Old Mar 29, 2011 | 11:20 PM
Guidosarducci62's Avatar
Guidosarducci62
7th Gear
Default Reflashed PCM now wont start!!
I have a 99 that needed the pcm reflashed due to a problem with a tuner. I removed it from the car and sent it in to be reflashed. After replacing it, I cleared all the codes and the security light remains on and the car wont start. Please help!!!
Old Mar 29, 2011 | 11:26 PM
Guidosarducci62
7th Gear
Also, the service manual says to perform the on-board system diagnotic check, which then has no reference page number to see what it is!
Old Mar 29, 2011 | 11:33 PM
seoulbrooks's Avatar
seoulbrooks
http://forums.corvetteforum.com/c5-s...-computer.html
There is a re-learn process. I'm sure one of the forum experts can help you out, or ask the vendor for the procedures. Good luck
Old Mar 29, 2011 | 11:38 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
TRY THIS!
BCM/PCM RELEARN PROCEDURE
You will need to conduct the PCM/BCM relearn process. This matches their handshake ID's and allows them to talk to each other.
Do this before you worry about VATS issues:
1. Turn on the key for 11 minutes.
2 Turn off the key for 30 seconds.
3. Repeat 1&2 two more times.
4. Turn on the key for 30 seconds.
The car should start and run with the new BCM. Good luck and report back on your progress.
Shirl
SD Racing Enterprises
Aguila, AZ
Coutersy of MrEracer
This will sync the PCM to the New BCM but all of your RPO options will not be retained. You will need a TECH II to program them into the new BCM.
Bill Curlee
Old Mar 29, 2011 | 11:51 PM
Guidosarducci62
7th Gear
Ill give it a shot and post an update. Thanks so much! BTW, what rpo options wont be maintained??? Thanks again
Old Mar 30, 2011 | 07:25 AM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
At least thats the way it SHOULD WORK!!
Old Mar 30, 2011 | 08:00 PM
Guidosarducci62
7th Gear
Update!! So far so good. I now have to do an idle relearn procedure. Ill let you know how it goes. Thanks again!
Old Dec 10, 2012 | 10:52 PM
Abnmarine's Avatar
Abnmarine
Originally Posted by Bill Curlee
TRY THIS!
Shirl
Aguila, AZ
Bill Curlee
Revived and old thread after searching for solutions of a code B2722. This is the first time it's happened. I've cleaned the key, tried a spare, electrical cleaner in the ignition. Any other tips to get the car home?
Old Dec 11, 2012 | 03:27 PM
tom01ss's Avatar
0tom01ss
Former Vendor
sounds like the tuner turned off the vats, and when you had it reflashed they are turned on.
To Reflashed PCM now wont start!!
