Fuel filter line removal tool
Old Mar 31, 2011 | 07:33 PM
General Lee's Avatar
General Lee
Default Fuel filter line removal tool
What brand or manufacturer tool have those that tackled
the job used with success?
TIA
Old Mar 31, 2011 | 07:36 PM
imavettegirl's Avatar
imavettegirl
any plastic fuel line set will do.
Old Mar 31, 2011 | 08:59 PM
LoneStarFRC's Avatar
LoneStarFRC
Lisle makes a set. They make a lot of specialty tools. Very affordable.
Old Mar 31, 2011 | 10:53 PM
johnson-rod's Avatar
johnson-rod
You might want to try it without the tool first. I found the tool to be more of a PIA than a a help. Just press the tabs together by hand. (this was on a '98)
Old Mar 31, 2011 | 10:59 PM
chevylad's Avatar
chevylad
I got mines from the local Autozone in a set of three different colored anodized aluminum pieces. It works fine on the stock line. It gave me grief on an after market AN adapter.
I've seen what looks like the same thing from several different manufacterers. The brand I have is OEM.
Old Mar 31, 2011 | 11:51 PM
00 Rooster's Avatar
00 Rooster
St. Jude Donor '08
the only thing I could find was a set made of plastic. they were cheap but actually worked. Id have bought better if I could have found them but its fine since they work and I wont be changing a lot of fuel filters.
Old Apr 1, 2011 | 01:41 PM
rboineau's Avatar
rboineau
I've found technique to be more important than which tool you use (as long as you are using the right size). I've only done a few but find that just shoving the tool in and pulling is usually frustrating. You might even break something if you are too rough. Insert the tool without too much force, then push/wiggle before pulling to try and separate. Works for me.
Old Apr 1, 2011 | 10:14 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
I went to a a friends heated garage with several other vette owners. We were all going to do some work. One of my task was to change my -02 Z fuel filter. Murphys Law says that you will forget the tool,, .. Murphy was right!!
Well, I made my own tool out of the little red protective cap on the new filter. It doesnt have to be a fancy tool. Just something to release the little brass fingers inside the hilter connection..
SECRET METHOD! Before you insert the tool,,, "PUSH IN" on the fuel line! This will release the fingers inside the filter connection. Slide the tool in and then pull on the line. It should easily pop out.
BC
Old Apr 2, 2011 | 03:30 PM
General Lee
Thanks for all the tips, and i have seen the Lisle set on there web site so im gonna check that one out at A/Z or Advance.
Old Apr 2, 2011 | 04:17 PM
LoneStarFRC
I bought my set when I was in the tools section at Sears one day.
Old Apr 2, 2011 | 08:51 PM
GeneT's Avatar
GeneT
The $5.99 X tool at Advance...just used it a week ago
Its the cheapest one they have too
Old Apr 3, 2011 | 06:26 AM
General Lee
Great I'll check it out, 'X tool' is that what it's called?
Old Apr 3, 2011 | 10:12 PM
General Lee
ok thanks I'll look at that one.
Old Apr 3, 2011 | 11:01 PM
Jay_Rich's Avatar
Jay_Rich
Good luck too ya! I bought a plastic one amd broke it! Tried for about 1 hour. I ended up cutting the line off. Hopefully urs comes off haha.
After cutting the line off I noticed why, all the prongs inside were bent down and the platic tool couldnt get under it
Jay
Old Apr 4, 2011 | 09:38 AM
GeneT's Avatar
GeneT
It looks like this
one end is 5/16" and the other 3/8". You close it over the single fuel line goward the engine and press it in to release little clips in the filter neck. You dont need to press invery far to release it, I didn't know I had it until i bumped it and saw the line was free. The back two fuel lines from your tanks are easy, use your finger on one side and a long shaft screwdriver on the other. You have to remove the plastic clips and reuse them on the new filter.
Don't forget to release the fuel pressure before you start. do it at the schraeder valve on the front of the drivers side fuel rail.
I have pictures if you want them
Order your filter from rockauto.com, its $33 + $5 shipping
Old Apr 4, 2011 | 11:32 AM
GeneT's Avatar
GeneT
http://www.cajundude.com/fuelfilter.htm
schraeder valve
http://c5help.com/fuel_injectors.htm
another
https://www.corvetteforum.com/techti...=123&TopicID=1
and
http://forums.corvetteforum.com/c5-t...el-filter.html
These are the links I used to walk thru it
and its located in the center of the car on the frame....above the exhaust where the exhaust pipes go from the center of the car to the outside
To Fuel filter line removal tool
